阅读:3320回复:0
利用Sensor实现android手机类似于微信摇一摇
更多 发布于:2012-09-06 13:43
传感器有几种类型:
方向传感器: Sensor.TYPE_ORIENTATION
加速度(重力)传感器: Sensor.TYPE_ACCELEROMETER
光线传感器: Sensor.TYPE_LIGHT
磁场传感器: Sensor.TYPE_MAGNETIC_FIELD
距离(临近性)传感器: Sensor.TYPE_PROXIMITY
温度传感器: Sensor.TYPE_TEMPERATURE
这里我们利用的是加速度传感器
package com.jamin.sensor;
import Android.app.Activity;
import Android.app.Service;
import Android.hardware.Sensor;
import Android.hardware.SensorEvent;
import Android.hardware.SensorEventListener;
import Android.hardware.SensorManager;
import Android.os.Bundle;
import Android.os.Vibrator;
import Android.util.Log;
import Android.view.View;
import Android.widget.Button;
import Android.widget.TextView;
public class SensorTestActivity extends Activity implements SensorEventListener{
    TextView tv = null;
    Button button = null;
    SensorManager sensorManager = null;
    Vibrator vibrator = null;
    @Override
        button = (Button) findViewById(R.id.button1);
        tv = (TextView) findViewById(R.id.textview1);
        button.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                // TODO Auto-generated method stub
                tv.setText("文本复原");
        sensorManager = (SensorManager) getSystemService(SENSOR_SERVICE);
        vibrator = (Vibrator) getSystemService(Service.VIBRATOR_SERVICE);
    @Override
    protected void onPause() {
        super.onPause();
        sensorManager.unregisterListener(this);
    @Override
    protected void onResume() {
        super.onResume();
        sensorManager.registerListener(this, sensorManager.getDefaultSensor(Sensor.TYPE_ACCELEROMETER), SensorManager.SENSOR_DELAY_NORMAL);
    @Override
    public void onAccuracyChanged(Sensor sensor, int accuracy) {
        //当传感器精度改变时回调该方法,Do nothing.
    @Override
    public void onSensorChanged(SensorEvent event) {
        int sensorType = event.sensor.getType();
        //values[0]:X轴,values[1]:Y轴,values[2]:Z轴
        float[] values = event.values;
        if(sensorType == Sensor.TYPE_ACCELEROMETER){
            if((Math.abs(values[0])>17||Math.abs(values[1])>17||Math.abs(values[2])>17)){
                Log.d("sensor ", "============ values[0] = " + values[0]);
                Log.d("sensor ", "============ values[1] = " + values[1]);
                Log.d("sensor ", "============ values[2] = " + values[2]);
                tv.setText("摇一摇");
                //摇动手机后,再伴随震动提示~~
                vibrator.vibrate(500);
记得在onresume和onpause的时候开关sensor的监听事件。
如果想调整sensor的敏感程度,就去修改,value[0,1,2] 大于的上限。
