阅读:1948回复:0
android学习笔记22--------------通过短信的号码获取联系人
更多 发布于:2012-09-06 13:43
使用前
使用后
public void readShortMessage()
        // 短信数据库查询
        ContentResolver cr = getContentResolver();
        Cursor cursor = cr.query(Uri.parse("content://sms/inbox"), null, null,
                null, null);
        String msg = "";
        while (cursor.moveToNext())
            int phoneColumn = cursor.getColumnIndex("address");
            int smsColumn = cursor.getColumnIndex("body");
            msg += cursor.getString(phoneColumn) + ":"
                    + cursor.getString(smsColumn) + "n";
            String contact=getContactNameFromPhoneNum(this.getApplicationContext(),cursor.getString(phoneColumn));
            getData(contact, cursor.getString(smsColumn));
            //getData(cursor.getString(phoneColumn), cursor.getString(smsColumn));
  // 短信数据库查询
    null, null);
  String msg = "";
[java]
public String getContactNameFromPhoneNum(Context context, String phoneNum)
        String contactName = "";
        ContentResolver cr = context.getContentResolver();
        Cursor pCur = cr.query(
        ContactsContract.CommonDataKinds.Phone.CONTENT_URI, null,
        ContactsContract.CommonDataKinds.Phone.NUMBER + " = ?",
        new String[]{ phoneNum }, null);
            if (pCur.moveToFirst())
                contactName = pCur
                        .getString(pCur
                                .getColumnIndex(ContactsContract.CommonDataKinds.Phone.DISPLAY_NAME));
                pCur.close();
        return contactName;
