阅读:2470回复:0
android学习笔记21--------------Android中RelativeLayout+ListView
更多 发布于:2012-09-06 13:43
效果图
public class ListViewActivity extends ListActivity
     @Override
     public void onCreate(Bundle savedInstanceState)
         // setContentView(R.layout.main);
         SimpleAdapter adapter = new SimpleAdapter(this, getData(),
                 R.layout.main, new String[]
                 {"title","info","img"}, new int[]
                 { R.id.title, R.id.info, R.id.img });
         setListAdapter(adapter);
     private List<Map<String, Object>> getData()
         List<Map<String, Object>> list = new ArrayList<Map<String, Object>>();
         Map<String, Object> map = new HashMap<String, Object>();
         map.put("title", "G1");
         map.put("info", "google 1");
         map.put("img", R.drawable.icon);
         list.add(map);
         map.put("title", "G2");
         map.put("info", "google 2");
         list.add(map);
         map.put("title", "G3");
         map.put("info", "google 3");
         list.add(map);
         return list;
  @Override
   list.add(map);
   list.add(map);
   list.add(map);
   return list;
[java]
     Android:orientation="vertical" Android:layout_width="fill_parent"
     Android:layout_height="fill_parent">
     <RelativeLayout
         Android:layout_width="wrap_content"
         Android:layout_height="wrap_content">
          <ImageView
             Android:id="@+id/img"
             Android:layout_margin="2px"/>
         <TextView
             Android:id="@+id/title"
             Android:layout_toRightOf="@id/img"
             Android:textColor="#FFFFFFFF"
             Android:textSize="22px" />
         <TextView
             Android:id="@+id/info"
             Android:layout_alignBottom="@id/img"
             Android:textSize="13px" />
     </RelativeLayout>
</LinearLayout>
<RelativeLayout
    <ImageView
   <TextView
   <TextView
  </RelativeLayout>
</LinearLayout>
ListActivity下有setListAdapter()方法
// ListView www.atcpu.com中某项被选中后的逻辑
[java]
<pre name="code" class="java">    @Override
     protected void onListItemClick(ListView l, View v, int position, long id)
         Log.v("MyListView4-click", (String) mData.get(position).get("title"));
