阅读:2670回复:0
android学习笔记16-------Android实现网络图片与html源码获取
更多 发布于:2012-09-06 13:43
获取指定网址的图片:
获取指定网址的html源码,这里是搜狐的网址举例。
MainActivity
[java]
package com.luku.netImage;
import com.luku.Junit.testJunit;
import Android.app.Activity;
import Android.content.Intent;
import Android.graphics.Bitmap;
import Android.graphics.BitmapFactory;
import Android.os.Bundle;
import Android.view.View;
import Android.view.View.OnClickListener;
import Android.widget.Button;
import Android.widget.EditText;
import Android.widget.ImageView;
import Android.widget.Toast;
public class MainActivity extends Activity
    Button getImagebutton;
    EditText imagePatheditText;
    ImageView imageView;
    Button exitbButton;
    Button gethtml;
    @Override
    public void onCreate(Bundle savedInstanceState)
        getImagebutton=(Button)findViewById(R.id.getImage);
        gethtml=(Button)findViewById(R.id.gethtml);
        exitbButton=(Button)findViewById(R.id.exit);
        imagePatheditText=(EditText)findViewById(R.id.ImagePath);
        imageView=(ImageView)findViewById(R.id.imageView);
        getImagebutton.setOnClickListener(new OnClickListener()
            @Override
            public void onClick(View v)
                try
                    byte[] data=testJunit.testGetImage(imagePatheditText.getText().toString());
                    Bitmap bm=BitmapFactory.decodeByteArray(data, 0, data.length);
                    imageView.setImageBitmap(bm);
                } catch (Exception e)
                    Toast.makeText(MainActivity.this, "获取图片失败", Toast.LENGTH_SHORT);
        gethtml.setOnClickListener(new OnClickListener()
            @Override
                Intent intent=new Intent(MainActivity.this, SecondActivity.class);
                MainActivity.this.startActivity(intent);
        exitbButton.setOnClickListener(new OnClickListener()
            @Override
                Android.os.Process.killProcess(Android.os.Process.myPid());
Button exitbButton;
Button gethtml;
@Override
   @Override
    try
   @Override
   @Override
[java]
import Android.widget.TextView;
public class SecondActivity extends Activity
    Button backbButton;
    TextView htmlTextView;
    @Override
    protected void onCreate(Bundle savedInstanceState)
        // TODO Auto-generated method stub
        setContentView(R.layout.second);
        backbButton=(Button)findViewById(R.id.back);
        htmlTextView=(TextView)findViewById(R.id.htmlView);
        try
            htmlTextView.setText(new String(testJunit.testGetHtml()));
            e.printStackTrace();
        backbButton.setOnClickListener(new OnClickListener()
            @Override
                SecondActivity.this.finish();
Button backbButton;
@Override
  try
   @Override
[java]
package com.luku.Junit;
import java.io.ByteArrayOutputStream;
import java.io.InputStream;
import java.net.HttpURLConnection;
import java.net.URL;
public class testJunit
     * 读取数据
     * @param inputStream
     * @return
     * @throws Exception
    public static byte[] readStream(InputStream inputStream) throws Exception
        byte[] buffer=new byte[1024];
        int len=-1;
        ByteArrayOutputStream byteArrayOutputStream=new ByteArrayOutputStream();
        while((len=inputStream.read(buffer))!=-1)
            byteArrayOutputStream.write(buffer,0,len);
        inputStream.close();
        byteArrayOutputStream.close();
        return byteArrayOutputStream.toByteArray();
     * 获取网上图片
     * @throws Exception
    public static byte[] testGetImage(String path) throws Exception
        URL url=new URL(path);
        HttpURLConnection conn=(HttpURLConnection)url.openConnection();
        conn.setConnectTimeout(6*1000);  //设置链接超时时间6s
        conn.setRequestMethod("GET");
        if(conn.getResponseCode()==200)
            InputStream inputStream=conn.getInputStream();
            return readStream(inputStream);
        return null;
     * 获取网址的html
     * @throws Exception
    public static byte[] testGetHtml() throws Exception
        String urlpath="http://www.sohu.com/";
        URL url=new URL(urlpath);
            byte[] data=readStream(inputStream);
            return data;
        return null;
  * 读取数据
  * @return
  * @throws Exception
  int len=-1;
  * 获取网上图片
  * @throws Exception
  return null;
  * 获取网址的html
  * @throws Exception
   return data;
  return null;
main.xml
[java]
    Android:orientation="vertical"
<TextView
    Android:text="图片路径"
    Android:textSize="20sp"
<EditText
    Android:layout_width="match_parent"
    Android:id="@+id/ImagePath"
    Android:text="http://avatar.csdn.net/C/9/A/1_yf210yf.jpg"></EditText>
<LinearLayout Android:id="@+id/linearLayout1" Android:layout_height="wrap_content" Android:layout_width="match_parent">
    <Button
            Android:text="获取图片"
            Android:layout_width="wrap_content"
            Android:id="@+id/getImage" Android:layout_height="wrap_content"></Button>
    <Button
            Android:text="获取html源码"
            Android:id="@+id/gethtml"
</LinearLayout>
<ImageView
    Android:id="@+id/imageView"
    Android:layout_width="wrap_content"></ImageView>
<Button
    Android:text="退出"
    Android:id="@+id/exit"
</LinearLayout>
<TextView
    Android:text="图片路径"
<EditText
    <Button
      Android:text="获取图片"
    <Button
</LinearLayout>
<ImageView
<Button
Android:text="退出"
</LinearLayout>
second.xml
[java]
      <Button
        Android:text="返回"
        Android:id="@+id/back"
    <ScrollView
    <TextView
        Android:id="@+id/htmlView"
        Android:layout_height="wrap_content"></TextView>
    </ScrollView>
</LinearLayout>
      <Button
     Android:text="返回"
    <ScrollView
    <TextView
    </ScrollView>
</LinearLayout>
[java]
<manifest xmlns:Android="http://schemas.Android.com/apk/res/Android"
      package="com.luku.netImage"
      Android:versionCode="1"
      Android:versionName="1.0">
    <uses-sdk Android:minSdkVersion="8" />
    <uses-permission Android:name="Android.permission.interNET"></uses-permission>
    <application Android:icon="@drawable/icon" Android:label="@string/app_name">
        <activity Android:name=".MainActivity"
            <intent-filter>
                <action Android:name="Android.intent.action.MAIN" />
                <category Android:name="Android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity Android:name=".SecondActivity"
             </activity>
    </application>
</manifest>
