阅读:6438回复:0
android学习笔记11------Activity之切换与参数传递
更多 发布于:2012-09-06 13:43
实现功能:
1.两个Activity之间的切换
2.两个Activity带返回值的切换
效果图:
点击切换Activity,或带返回值的Activity,出现:
点击关闭,其中带返回值的效果如下:
import Android.app.Activity;
import Android.content.Intent;
import Android.os.Bundle;
import Android.view.View;
import Android.view.View.OnClickListener;
import Android.widget.Button;
import Android.widget.TextView;
public class Main extends Activity
    Button button;
    Button button2;
    TextView textView;
    @Override
    public void onCreate(Bundle savedInstanceState)
        button=(Button)findViewById(R.id.button);
        button2=(Button)findViewById(R.id.button2);
        textView=(TextView)findViewById(R.id.display);
        button.setOnClickListener(new OnClickListener()
            @Override
            public void onClick(View v)
                 * 向新activity传参数
                Intent intent= new Intent(Main.this, OtherActivity.class);
                intent.putExtra("age", 10);
                intent.putExtra("name", "lingming");
                Main.this.startActivity(intent);
        button2.setOnClickListener(new OnClickListener()
            @Override
                 * 带返回值的Activity切换
                Main.this.startActivityForResult(intent, 3);//3是标示请求码,随便写
     *  接收带有返回值的Activity方法
    @Override
    protected void onActivityResult(int requestCode, int resultCode, Intent data)
        super.onActivityResult(requestCode, resultCode, data);
        textView.setText("requestCode:"+requestCode+'n'+
                         "resultCode:"+resultCode+'n'+
                         "接收到:"+data.getStringExtra("返回值")
Button button;
Button button2;
TextView textView;
@Override
   @Override
     * 向新activity传参数
   @Override
     * 带返回值的Activity切换
@Override
[java]
public class OtherActivity extends Activity
    TextView textView;
    Button button;
    @Override
    protected void onCreate(Bundle savedInstanceState)
        setContentView(R.layout.otherui);
        Intent intent=this.getIntent();
        int age=intent.getIntExtra("age", 0);
        String name=intent.getStringExtra("name");
        textView=(TextView)findViewById(R.id.textView);
        textView.setText("年龄:"+age+'n'+"姓名:"+name);
        button=(Button)findViewById(R.id.finish);
            @Override
                Intent intent=new Intent();
                intent.putExtra("返回值", "这是返回值");
                OtherActivity.this.setResult(12, intent);
                OtherActivity.this.finish();
TextView textView;
Button button;
@Override
   @Override
main.xml
[java]
    Android:orientation="vertical"
<TextView
    Android:text="这是MainActivity"
<Button
        Android:text="切换Activity"
        Android:id="@+id/button"
        Android:layout_width="wrap_content"
        Android:layout_height="wrap_content"></Button>
<Button
        Android:text="带返回值的Activity"
        Android:id="@+id/button2"
<TextView
    Android:id="@+id/display"
</LinearLayout>
<TextView
<Button
<Button
<TextView
</LinearLayout>
otherui.xml
[java]
<TextView
    Android:text="这是新的Activity"
<TextView
    Android:id="@+id/textView"
    Android:layout_height="wrap_content"></TextView>
<Button
    Android:text="关闭"
    Android:id="@+id/finish"
</LinearLayout>
<TextView
<TextView
<Button
Android:text="关闭"
</LinearLayout>
注意第二个Activity要在AndroidMainfest.xml中进行配置
[java]
<manifest xmlns:Android="http://schemas.Android.com/apk/res/Android"
      package="com.luku.mulActivity"
      Android:versionCode="1"
      Android:versionName="1.0">
    <uses-sdk Android:minSdkVersion="8" />
    <application Android:icon="@drawable/icon" Android:label="@string/app_name">
        <activity Android:name=".Main"
            <intent-filter>
                <action Android:name="Android.intent.action.MAIN" />
                <category Android:name="Android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity Android:name=".OtherActivity"
        </activity>
    </application>
</manifest>
