阅读:9575回复:0
android学习笔记9--------------SD卡读写文件
更多 发布于:2012-09-06 13:44
把文件存入SD卡中
首先加入读写权限
SD卡创建与删除文件权限
<uses-permission Android:name="Android.permission.MOUNT_UNMOUNT_FILESYSTEMS"></uses-permission>
SD卡写入数据权限
<uses-permission Android:name="Android.permission.WRITE_EXTERNAL_STORAGE"></uses-permission>
点击保存前:
点击保存:
SD卡根目录多了123.txt文件
点击读取:
读取成功。
代码:
[java]
import java.io.File;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import java.io.InputStream;
import Android.app.Activity;
import Android.os.Bundle;
import Android.os.Environment;
import Android.view.View;
import Android.view.View.OnClickListener;
import Android.widget.Button;
import Android.widget.EditText;
import Android.widget.TextView;
import Android.widget.Toast;
import com.luku.file.service.FileService;
public class fileActivity extends Activity
    private EditText editText=null;
    private Button   button =null;
    private TextView content =null;
    private Button   read=null;
    private TextView textView1=null;
    private Button   exit=null;
    @Override
    public void onCreate(Bundle savedInstanceState)
        textView1=(TextView)findViewById(R.id.textView1);
        content=(TextView)findViewById(R.id.content);
        editText=(EditText)findViewById(R.id.filename);
        button=(Button)findViewById(R.id.baocun);
        read=(Button)findViewById(R.id.read);
        exit=(Button)findViewById(R.id.exit);
        button.setOnClickListener(listener);
        read.setOnClickListener(listener);
        exit.setOnClickListener(listener);
    private OnClickListener listener=new OnClickListener()
        int resId = R.string.success;
        @Override
        public void onClick(View v)
            Button btn=(Button)v;
            File file=new File(Environment.getExternalStorageDirectory(),//得到SD卡根目录
                    editText.getText().toString());                      //保存文件的文件名
            switch (btn.getId())
                case R.id.baocun:
                if(Environment.getExternalStorageState().
                        equals(Environment.MEDIA_MOUNTED)) //判断SD卡是否存在,并且可以可以读写
                    try
                        FileOutputStream stream=new FileOutputStream(file);
                        FileService.save(stream, content.getText().toString());
                    catch (IOException e)
                        e.printStackTrace();
                        resId = R.string.error;
                        Toast.makeText(fileActivity.this, resId, Toast.LENGTH_LONG).show();
                else
                    Toast.makeText(fileActivity.this, "SD卡不存在或写保护", Toast.LENGTH_LONG).show();
                    break;
                case R.id.read:
                    try
                        InputStream instream=new FileInputStream(file);
                        String string=FileService.read(instream);
                        System.out.println(string);
                        textView1.setText(string.toString());
                    } catch (Exception e)
                        Toast.makeText(fileActivity.this, "读取失败", Toast.LENGTH_LONG).show();
                    break;
                case R.id.exit:
                    Android.os.Process.killProcess(Android.os.Process.myPid());
                    break;
                default:
                    break;
@Override
  @Override
    case R.id.baocun:
     try
    else
     break;
    case R.id.read:
     try
     break;
    case R.id.exit:
     break;
    default:
     break;
FileService文件
[java]
import java.io.ByteArrayOutputStream;
import java.io.OutputStream;
public class FileService
     * 保存数据
     * @param stream
     * @param content
     * @throws IOException
    public static void save(OutputStream stream , String content) throws IOException
        stream.write(content.getBytes());
        stream.close();
     * 读取数据
     * @param inStream
     * @return
    public static String read(InputStream inStream) throws IOException
        ByteArrayOutputStream outputStream=new ByteArrayOutputStream();
        int len=-1;
        byte[] buffer =new byte[1024];
        while( (len=inStream.read(buffer))!=-1 )
            outputStream.write(buffer, 0, len);
        byte[] data = outputStream.toByteArray();
        inStream.close();
        outputStream.close();
        return new String(data);
  * 保存数据
  * @param stream
  * @param content
  stream.close();
  * 读取数据
  * @param inStream
  * @return
  int len=-1;
  inStream.close();
main.xml文件
[java]
<LinearLayout xmlns:Android="http://schemas.android.com/apk/res/android"
    Android:orientation="vertical"
    <RelativeLayout xmlns:Android="http://schemas.android.com/apk/res/android"
        Android:layout_height="wrap_content">
            <TextView
                Android:layout_width="90px"
                Android:text="文件名称:"
                Android:textSize="21px"
                Android:id="@+id/filenamelebal"
            <EditText
                 Android:layout_toRightOf="@id/filenamelebal"
                 Android:layout_alignTop="@id/filenamelebal"
                 Android:id="@+id/filename"
            ></EditText>
        ></RelativeLayout>
        <TextView
                Android:text="内容:"
        <EditText
                 Android:minLines="3"
                 Android:id="@+id/content"
            ></EditText>
        <LinearLayout Android:id="@+id/linearLayout1" Android:layout_width="match_parent" Android:layout_height="wrap_content">
            <Button
                Android:id="@+id/baocun"
                Android:text="保存"
                Android:layout_width="wrap_content"></Button>
            <Button
                Android:text="读取"
                Android:id="@+id/read"
                Android:layout_height="wrap_content"></Button>
            <Button
                Android:text="退出"
                Android:id="@+id/exit"
        </LinearLayout>
        <TextView
                Android:text="读取内容显示"
                Android:id="@+id/textView1"
                </TextView>
</LinearLayout>
      <TextView
      <EditText
      ></EditText>
     ></RelativeLayout>
     <TextView
       Android:text="内容:"
  <EditText
      ></EditText>
         <Button
          Android:text="保存"
         <Button
          Android:text="读取"
         <Button
          Android:text="退出"
     </LinearLayout>
     <TextView
       </TextView>
</LinearLayout>
配置文件
[java]
<manifest xmlns:Android="http://schemas.android.com/apk/res/android"
      package="com.luku.file"
      Android:versionCode="1"
      Android:versionName="1.0">
    <uses-sdk Android:minSdkVersion="8" />
    <application Android:icon="@drawable/icon" Android:label="@string/app_name">
        <uses-library Android:name="Android.test.runner"></uses-library>
        <activity Android:name=".fileActivity"
            <intent-filter>
                <action Android:name="Android.intent.action.MAIN" />
                <category Android:name="Android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
    <instrumentation
        Android:name="Android.test.InstrumentationTestRunner"
        Android:targetPackage="com.luku.file"
        Android:label="Test for my app"
    ></instrumentation>
</manifest>
            <intent-filter>
            </intent-filter>
        </activity>
    </application>
    <instrumentation
    ></instrumentation>
</manifest>
