阅读:3108回复:0
android学习笔记3--------短信发送器
更多 发布于:2012-09-06 13:44
效果图:
import java.util.List;
import Android.app.Activity;
import Android.os.Bundle;
import Android.telephony.SmsManager;
import Android.view.View;
import Android.view.View.OnClickListener;
import Android.widget.Button;
import Android.widget.EditText;
import Android.widget.Toast;
public class SendMessageActivity extends Activity
    private EditText mobileEditText;
    private EditText contenText;
    private Button sendbButton;
    private Button exitButton;
    @Override
    public void onCreate(Bundle savedInstanceState)
        mobileEditText=(EditText)findViewById(R.id.mobile);
        contenText=(EditText)findViewById(R.id.content);
        sendbButton=(Button)findViewById(R.id.send);
        exitButton=(Button)findViewById(R.id.exit);
        sendbButton.setOnClickListener(listener);
        exitButton.setOnClickListener(listener);
    private OnClickListener listener=new OnClickListener()
        @Override
        public void onClick(View v)
            Button button=(Button)v;
            switch (button.getId())
                case R.id.send:
                    String mobile=mobileEditText.getText().toString();
                    String contentString=contenText.getText().toString();
                    SmsManager smsManager=SmsManager.getDefault();
                    //Intent intent=new Intent();
                    //intent.setAction(Intent.ACTION_SENDTO);
                    //intent.setData(Uri.parse("smsto:"+mobile));
                    if(contentString.length()>70)
                        List<String> contents=smsManager.divideMessage(contentString);
                        for(String sms:contents)
                            smsManager.sendTextMessage(mobile, null, sms, null, null);
                            //intent.putExtra("sms_body", sms);
                            //SendMessageActivity.this.startActivity(intent);
                    else
                        smsManager.sendTextMessage(mobile, null, contentString, null, null);
                        //intent.putExtra("sms_body", contentString);
                    Toast.makeText(SendMessageActivity.this, "短信已发送", Toast.LENGTH_SHORT).show();
                    break;
                case R.id.exit:
                    Android.os.Process.killProcess(Android.os.Process.myPid());
                    break;
                default:
                    break;
@Override
  @Override
    case R.id.send:
     else
     break;
    case R.id.exit:
     break;
    default:
     break;
main.xml文件
[java]
     Android:orientation="vertical"
<TextView
     Android:text="请输入手机号"
<EditText
     Android:id="@+id/mobile"
     Android:layout_width="match_parent"
     ></EditText>
<TextView
     Android:layout_width="wrap_content"
     Android:text="请输入短信内容"
     ></TextView>
<EditText
     Android:id="@+id/content"
     Android:lines="3"
     ></EditText>
<Button
     Android:id="@+id/send"
     Android:text="发送短信"
     ></Button>
<Button
      Android:id="@+id/exit"
      Android:text="退出软件"
      ></Button>
</LinearLayout>
<TextView
<EditText
  ></EditText>
<TextView
  ></TextView>
<EditText
  Android:lines="3"
  ></EditText>
<Button
  Android:text="发送短信"
  ></Button>
<Button
   Android:text="退出软件www.atcpu.com"
   ></Button>
</LinearLayout>
加入权限:
  <uses-permission Android:name="Android.permission.SEND_SMS"></uses-permission>
