阅读:2858回复:0
android http 本地 web服务(tomcat)
更多 发布于:2012-09-06 13:44
1. Android代码
01
<b>public class JobActivity extends Activity {
02
    private TextView show;
03
    private EditText txt;
04
    private Button btn;
05
06
07
    @Override
08
09
10
11
12
        ConnectivityManager con=(ConnectivityManager)getSystemService(Activity.CONNECTIVITY_SERVICE);
13
        boolean wifi=con.getNetworkInfo(ConnectivityManager.TYPE_WIFI).isConnectedOrConnecting();
14
        boolean internet=con.getNetworkInfo(ConnectivityManager.TYPE_MOBILE).isConnectedOrConnecting();
15
        if(wifi ){
16
            show = (TextView)findViewById(R.id.show);
17
            txt = (EditText)findViewById(R.id.txt);
18
            btn = (Button)findViewById(R.id.btn);
19
            btn.setOnClickListener(new OnClickListener() {
20
            @Override
21
               public void onClick(View v) {
22
                show.setText("dianjile");
23
                dopost(txt.getText().toString());
24
25
26
27
28
29
    private void dopost(String val){
30
        //封装数据
31
        Map<String, String> parmas = new HashMap<String, String>();
32
        parmas.put("name", val);
33
       </b><p><b>        DefaultHttpClient client = new DefaultHttpClient();//http客户端</b></p>
34
<p><b>        //这个地方需要注意:如果是调试器 </b><span style="color:#ff0000;font-family:verdana, 'ms song', 宋体, Arial, 微软雅黑, Helvetica, sans-serif;text-align:left;white-space:normal;background-color:#ffffff;">10.0.2.2 本机地址;真机上:则是路由器中电脑地址</span></p>
35
<b>        HttpPost httpPost = new HttpPost("http://192.168.2.100:80/loowj/Android$Android$go");
36
        ArrayList<BasicNameValuePair> pairs = new ArrayList<BasicNameValuePair>();
37
        if(parmas != null){
38
            Set<String> keys = parmas.keySet();
39
            for(Iterator<String> i = keys.iterator(); i.hasNext();) {
40
                 String key = (String)i.next();
41
                 pairs.add(new BasicNameValuePair(key, parmas.get(key)));
42
43
44
45
     try {
46
            UrlEncodedFormEntity p_entity = new UrlEncodedFormEntity(pairs, "utf-8");
47
48
             *  将POST数据放入HTTP请求
49
50
            httpPost.setEntity(p_entity);
51
52
             *  发出实际的HTTP POST请求
53
54
            TextView tv = (TextView)findViewById(R.id.state);
55
            tv.setText("start post:");
56
            HttpResponse response = client.execute(httpPost);
57
            tv.setText((response.getStatusLine().getStatusCode() +""));
58
59
            HttpEntity entity = response.getEntity();
60
            InputStream content = entity.getContent();
61
            String returnConnection = convertStreamToString(content);
62
            show.setText(returnConnection);
63
     } catch (IllegalStateException e) {
64
      e.printStackTrace();
65
     } catch (IOException e) {
66
67
68
69
70
     private String convertStreamToString(InputStream is) {
71
      BufferedReader reader = new BufferedReader(new InputStreamReader(is));
72
            StringBuilder sb = new StringBuilder();
73
            String line = null;
74
            try {
75
                 while ((line = reader.readLine()) != null) {
76
                      sb.append(line);
77
78
79
80
            } finally {
81
                 try {
82
                      is.close();
83
84
85
86
87
            return sb.toString();
88
89
}</b>
2.Android 配置文件
<b><?xml version="1.0" encoding="utf-8"?>
2
<manifest xmlns:Android="http://schemas.Android.com/apk/res/Android"
3
    package="com.loowj.core"
4
    Android:versionCode="1"
5
    Android:versionName="1.0" >
6
7
    <uses-sdk Android:minSdkVersion="10" /></b>
01
<b>     <span style="color:#e53333;">//注意加上网络权限</span>     <uses-permission Android:name="Android.permission.ACCESS_NETWORK_STATE"/>
02
    <uses-permission Android:name="Android.permission.INTERNET"/>
03
    <application
04
        Android:icon="@drawable/ic_launcher"
05
        Android:label="@string/app_name" >
06
        <activity
07
            Android:name="loowj.JobActivity"
08
09
            <intent-filter>
10
                <action Android:name="Android.intent.action.MAIN" />
11
12
                <category Android:name="Android.intent.category.LAUNCHER" />
13
            </intent-filter>
14
        </activity>
15
    </application>
16
17
</manifest></b>
