阅读:2424回复:0
Android实现ListView异步加载图片
更多 发布于:2012-09-06 13:49
ListView异步加载图片是非常实用的方法,凡是是要通过网络获取图片资源一般使用这种方法比较好,用户体验好,下面就说实现方法,先贴上主方法的代码:
package cn.wangmeng.test;
import java.io.IOException;
import java.io.InputStream;
import java.lang.ref.SoftReference;
import java.net.MalformedURLException;
import java.net.URL;
import java.util.HashMap;
import Android.graphics.drawable.Drawable;
import Android.os.Handler;
import Android.os.Message;
public class AsyncImageLoader {
     private HashMap<String, SoftReference<Drawable>> imageCache;
         public AsyncImageLoader() {
             imageCache = new HashMap<String, SoftReference<Drawable>>();
         public Drawable loadDrawable(final String imageUrl, final ImageCallback imageCallback) {
             if (imageCache.containsKey(imageUrl)) {
                 SoftReference<Drawable> softReference = imageCache.get(imageUrl);
                 Drawable drawable = softReference.get();
                 if (drawable != null) {
                     return drawable;
             final Handler handler = new Handler() {
                 public void handleMessage(Message message) {
                     imageCallback.imageLoaded((Drawable) message.obj, imageUrl);
             new Thread() {
                 @Override
                 public void run() {
                     Drawable drawable = loadImageFromUrl(imageUrl);
                     imageCache.put(imageUrl, new SoftReference<Drawable>(drawable));
                     Message message = handler.obtainMessage(0, drawable);
                     handler.sendMessage(message);
             }.start();
             return null;
        public static Drawable loadImageFromUrl(String url) {
            URL m;
            InputStream i = null;
            try {
                m = new URL(url);
                i = (InputStream) m.getContent();
            } catch (MalformedURLException e1) {
                e1.printStackTrace();
            } catch (IOException e) {
                e.printStackTrace();
            Drawable d = Drawable.createFromStream(i, "src");
            return d;
         public interface ImageCallback {
             public void imageLoaded(Drawable imageDrawable, String imageUrl);
以上代码是实现异步获取图片的主方法,SoftReference是软,是为了更好的为了系统回收变量,重复的URL直接返回已有的资源,实现回调函数,让数据成功后,更新到UI线程。
几个辅助类文件:
public class ImageAndText {
        private String imageUrl;
        private String text;
        public ImageAndText(String imageUrl, String text) {
            this.imageUrl = imageUrl;
            this.text = text;
        public String getImageUrl() {
            return imageUrl;
        public String getText() {
            return text;
import Android.view.View;
import Android.widget.ImageView;
import Android.widget.TextView;
public class ViewCache {
        private View baseView;
        private TextView textView;
        private ImageView imageView;
        public ViewCache(View baseView) {
            this.baseView = baseView;
        public TextView getTextView() {
            if (textView == null) {
                textView = (TextView) baseView.findViewById(R.id.text);
            return textView;
        public ImageView getImageView() {
            if (imageView == null) {
                imageView = (ImageView) baseView.findViewById(R.id.image);
            return imageView;
ViewCache是辅助获取adapter的子元素布局
import java.util.List;
import cn.wangmeng.test.AsyncImageLoader.ImageCallback;
import Android.app.Activity;
import Android.view.LayoutInflater;
import Android.view.ViewGroup;
import Android.widget.ArrayAdapter;
import Android.widget.ListView;
public class ImageAndTextListAdapter extends ArrayAdapter<ImageAndText> {
        private ListView listView;
        private AsyncImageLoader asyncImageLoader;
        public ImageAndTextListAdapter(Activity activity, List<ImageAndText> imageAndTexts, ListView listView) {
            super(activity, 0, imageAndTexts);
            this.listView = listView;
            asyncImageLoader = new AsyncImageLoader();
        public View getView(int position, View convertView, ViewGroup parent) {
            Activity activity = (Activity) getContext();
            // Inflate the views from XML
            View rowView = convertView;
            ViewCache viewCache;
            if (rowView == null) {
                LayoutInflater inflater = activity.getLayoutInflater();
                rowView = inflater.inflate(R.layout.image_and_text_row, null);
                viewCache = new ViewCache(rowView);
                rowView.setTag(viewCache);
            } else {
                viewCache = (ViewCache) rowView.getTag();
            ImageAndText imageAndText = getItem(position);
            // Load the image and set it on the ImageView
            String imageUrl = imageAndText.getImageUrl();
            ImageView imageView = viewCache.getImageView();
            imageView.setTag(imageUrl);
            Drawable cachedImage = asyncImageLoader.loadDrawable(imageUrl, new ImageCallback() {
                public void imageLoaded(Drawable imageDrawable, String imageUrl) {
                    ImageView imageViewByTag = (ImageView) listView.findViewWithTag(imageUrl);
                    if (imageViewByTag != null) {
                        imageViewByTag.setImageDrawable(imageDrawable);
            if (cachedImage == null) {
                imageView.setImageResource(R.drawable.default_image);
            }else{
                imageView.setImageDrawable(cachedImage);
            // Set the text on the TextView
            TextView textView = viewCache.getTextView();
            textView.setText(imageAndText.getText());
            return rowView;
ImageAndTextListAdapter是实现ListView的Adapter,里面有个技巧就是imageView.setTag(imageUrl),setTag是存储数据的,这样是为了保证在回调函数时,listview去更新自己对应item,大家仔细阅读就知道了。
最后贴出布局文件:
              Android:orientation="horizontal"
              Android:layout_height="wrap_content">
        <ImageView Android:id="@+id/image"
                   Android:layout_width="wrap_content"
        <TextView Android:id="@+id/text"
                  Android:layout_height="wrap_content"/>
</LinearLayout>
摘自  weizhiai12的专栏
