阅读:2329回复:0
Android中Socket通讯类
更多 发布于:2012-09-06 13:49
public class SocketClient
    public boolean mClientFlag = false;
    private static Socket client;
    public SocketClient()
        Log.d("WineStock", "WineStock SocketClient()");
        client = new Socket();
    public SocketClient(String HostName, int iPort)
        client=new Socket();
        SocketAddress socketAddress = new InetSocketAddress(HostName, iPort);
        try
            Log.d("WineStock", "WineStock SocketClient connect");
            client.connect(socketAddress, 3000);
        catch (IOException e) {
            // TODO Auto-generated catch block
            Log.d("WineStock", "WineStock SocketClient IOException");
        } catch (IllegalArgumentException e1) {
            // TODO: handle exception
            Log.d("WineStock", "WineStock SocketClient IllegalArgumentException ");
        return ;
    public boolean SocketConnect(String HostName, int iPort)
        try
            Log.d("WineStock", "WineStock SocketConnect connect ");
            Log.d("WineStock", "WineStock SocketConnect IOException ");
            Log.d("WineStock", "WineStock SocketConnect IllegalArgumentException ");
        return true;
    public void SocketClose()
        try {
            client.close();
        } catch (IOException e) {
            Log.d("WineStock", "socket close error"+e.getMessage());
    // 建立连接
    public static boolean SClient(SocketSendModel SendModel) throws UnknownHostException, IOException
        boolean bRet = false;
        try
            if(client.isConnected())
                //发送请求
                sendMessage(SendModel);
                bRet    =    true;
        catch (UnknownHostException e)
             Log.d("WineStock", "socket SClienterror"+e.getMessage());
        catch (IOException e1)
        return bRet;
    // 发送请求www.atcpu.com
    private static void sendMessage(SocketSendModel model) throws IOException
        //boolean bRet = false;
        try
            PrintWriter out = new PrintWriter(client.getOutputStream());
            out.print(objToJsonString(model).replace("\n", " "));
            out.flush();
            //bRet = true;
        return;
    // 接收服务器数据
    public static String readMessage() throws IOException
        String str    =    "";
        try
            BufferedReader br = new BufferedReader(new InputStreamReader(client.getInputStream()));
            str    =    br.readLine().replace("{", "").replace("}", "").replace("\"", "");
        catch ( IOException e)
        return str;
    // 将java Object对象转换为Json对象
    private  static String objToJsonString(Object obj) {
        // 初始化返回值
        String json = "str_empty";
        if (obj == null) {
            return json;
        StringBuilder buff = new StringBuilder();
        Field fields[] = obj.getClass().getFields();
        try {
            buff.append("[");
            buff.append("{");
            int i = 0;
            for (Field field : fields) {
                if (i != 0) {
                    buff.append(",");
                buff.append(field.getName());
                buff.append(":");
                buff.append("\"");
                buff.append(field.get(obj) == null ? "" : field.get(obj));
                buff.append("\"");
                i++;
            buff.append("}");
            buff.append("]");
            json = buff.toString();
        } catch (Exception e) {
            throw new RuntimeException("cause:" + e.toString());
        return json;
摘自  weizhiai12的专栏
