阅读:2454回复:0
Android获取手机和系统版本等信息的代码
更多 发布于:2012-09-06 13:51
[html] 有时候需要统计手机的型号和版本号,利用程序可以获取到相应的手机信息,对比两部手机发现,厂商不同,某个信息显示方式也不尽相同,具体见:
[html]
[html] String phoneInfo = "Product: " + Android.os.Build.PRODUCT;
        phoneInfo += ", cpu_ABI: " + Android.os.Build.CPU_ABI;
        phoneInfo += ", TAGS: " + Android.os.Build.TAGS;
        phoneInfo += ", VERSION_CODES.BASE: " + Android.os.Build.VERSION_CODES.BASE;
        phoneInfo += ", MODEL: " + Android.os.Build.MODEL;
        phoneInfo += ", SDK: " + Android.os.Build.VERSION.SDK;
        phoneInfo += ", VERSION.RELEASE: " + Android.os.Build.VERSION.RELEASE;
        phoneInfo += ", DEVICE: " + Android.os.Build.DEVICE;
        phoneInfo += ", DISPLAY: " + Android.os.Build.DISPLAY;
        phoneInfo += ", BRAND: " + Android.os.Build.BRAND;
        phoneInfo += ", BOARD: " + Android.os.Build.BOARD;
        phoneInfo += ", FINGERPRINT: " + Android.os.Build.FINGERPRINT;
        phoneInfo += ", ID: " + Android.os.Build.ID;
        phoneInfo += ", MANUFACTURER: " + Android.os.Build.MANUFACTURER;
        phoneInfo += ", USER: " + Android.os.Build.USER;
        // Toast.makeText(this, phoneInfo, Toast.LENGTH_LONG).show();
        TextView t = (TextView) findViewById(R.id.main_phoneinfo);
        t.setText(phoneInfo);
