阅读:2045回复:0
Android如何使用样式创建半透明窗体
更多 发布于:2012-09-06 13:51
本示例介绍如何使用Android系统样式和自定义样式创建半透明界面。
1. 定义清单文件(AndroidManifest.xml)
<manifest xmlns:Android="http://schemas.Android.com/apk/res/Android"
      package="my.andriod.test"
      Android:versionCode="1"
      Android:versionName="1.0">
    <application Android:icon="@drawable/icon" Android:label="@string/app_name">
        <!-- 使用自定义半透明主题样式  Android:theme="@style/Theme.Translucent" -->
        <activity Android:name=".TranslucentActivity"
                  Android:theme="@style/Theme.Translucent">
            <intent-filter>
                <action Android:name="Android.intent.action.MAIN" />
                <category Android:name="Android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <!-- 使用Android系统半透明主题样式
                  Android:theme="@Androidtyle/Theme.Translucent">
            <intent-filter>
            </intent-filter>
        </activity>
    </application>
    <uses-sdk Android:minSdkVersion="9" />
</manifest>
2. 定义字符串资源(strings.xml)
<resources>
    <string name="hello">Hello World, TranslucentActivity!</string>
    <string name="app_name">TranslucentActivity</string>
    <string name="activity_translucent">App/Activity/Translucent</string>
    <string name="translucent_background">Example of how you can make an
            activity have a translucent background, compositing over
            whatever is behind it.</string>
</resources>
3. 定义自定义样式(values/styles.xml)
<resources>
    <!-- 继承Android系统的半透明主题样式,并指定半透明背景的颜色、隐藏窗口标题和前景色  -->
    <style name="Theme.Translucent" parent="Androidtyle/Theme.Translucent">
        <item name="Android:windowBackground">@drawable/translucent_background</item>
        <item name="Android:windowNoTitle">true</item>
        <item name="Android:colorForeground">#fff</item>
    </style>
</resources>
4. 定义半透明颜色(colors.xml)
<resources>
    <drawable name="translucent_background">#e0000000</drawable>
</resources>
5. 定义布局文件(translucent_background.xml)
<!-- 在Activity中显示文本 -->
<TextView xmlns:Android="http://schemas.Android.com/apk/res/Android" Android:id="@+id/text"
    Android:layout_width="match_parent" Android:layout_height="match_parent"
    Android:gravity="center_vertical|center_horizontal"
    Android:text="@string/translucent_background"/>
6. 创建Activity(TranslucentActivity.java
package my.andriod.test;
import Android.app.Activity;
import Android.os.Bundle;
publicclass TranslucentActivity extends Activity {
    /** Activity首次创建时,调用这个方法 */
    @Override
    publicvoid onCreate(Bundle savedInstanceState) {
        //填充布局
        setContentView(R.layout.translucent_background);
