阅读:2336回复:0
图片等比例缩放
更多 发布于:2012-09-06 13:52
图片的等比例缩放,第一个参数是图片路径,第二个是最终所需要图片的(宽高里取值最大的)的最大值
[java] // 限制值MaxSize*(2/3)=实际使用值的比较值IMAGE_MAX_SIZE
    // 例如:限制图片大小为400,则实际使用的比较值应为400*(2/3)
    // 260*2/3=390
    public static Bitmap decodeFile(String path, int MaxSize) {
        File f = new File(path);
        int IMAGE_MAX_SIZE = MaxSize * 2 / 3;
        Bitmap b = null;
        try {
            // Decode image size
            BitmapFactory.Options o = new BitmapFactory.Options();
            o.inJustDecodeBounds = true;
            //FileInputStream fis = new FileInputStream(f);
            //BitmapFactory.decodeStream(fis, null, o);
            //fis.close();
            double scale = 1;
            if (o.outHeight > IMAGE_MAX_SIZE || o.outWidth > IMAGE_MAX_SIZE) {
                scale = Math.pow(2, (int) Math.round(Math.log(IMAGE_MAX_SIZE / (double) Math.max(o.outHeight, o.outWidth)) / Math.log(0.5)));
            // Decode with inSampleSize
            BitmapFactory.Options o2 = new BitmapFactory.Options();
            o2.inSampleSize = (int) scale;
            b = BitmapFactory.decodeStream(fis, null, o2);
            fis.close();
        } catch (FileNotFoundException e) {
        } catch (IOException e) {
            // TODO Auto-generated catch block
            e.printStackTrace();
        return b;
