阅读:3414回复:0
将String保存成文件
更多 发布于:2012-09-06 13:52
[html] 如题,将String保存成文件。
如题,将String保存成文件。[html] /**
  * 将String数据存为文件
public static File getFileFromBytes(String name,String path) {
    byte[] b=name.getBytes();
     BufferedOutputStream stream = null;
     File file = null;
     try {
         file = new File(path);
         FileOutputStream fstream = new FileOutputStream(file);
         stream = new BufferedOutputStream(fstream);
         stream.write(b);
     } catch (Exception e) {
         e.printStackTrace();
     } finally {
         if (stream != null) {
             try {
                 stream.close();
             } catch (IOException e1) {
                 e1.printStackTrace();
     return file;
     * 将String数据存为文件
        File file = null;
        try {
            stream.write(b);
        } finally {
                try {
                    stream.close();
        return file;
byte数据保存为文件:
[html] /**
  * 将byte数据存为文件 www.atcpu.com/bbs
public static File getFileFromBytes(byte[] b,String path) {
     File file = null;
     try {
         stream.write(b);
     } finally {
             try {
                 stream.close();
     return file;
