阅读:1755回复:0
将应用raw里的文件copy到sd卡实现
更多 发布于:2012-09-06 13:52
把APK的资源文件copy到SD卡下的实现。
[html]        /*
* 将raw里的文件copy到sd卡下
public void copyResToSdcard(String name){//name为sd卡下制定的路径
     Field[] raw = R.raw.class.getFields();
    for (Field r : raw) {
         try {
        //     System.out.println("R.raw." + r.getName());
             int id=getResources().getIdentifier(r.getName(), "raw", getPackageName());
               if(!r.getName().equals("allapps")){
                     String path=name+"/"+r.getName()+".png";
                 BufferedOutputStream bufEcrivain = new BufferedOutputStream((new FileOutputStream(new File(path))));
                 BufferedInputStream VideoReader = new BufferedInputStream(getResources().openRawResource(id));
                 byte[] buff = new byte[20*1024];
                 int len;
                 while( (len = VideoReader.read(buff)) > 0 ){
                     bufEcrivain.write(buff,0,len);
                 bufEcrivain.flush();
                 bufEcrivain.close();
                 VideoReader.close();
         } catch (Exception e) {
             e.printStackTrace();
