阅读:2217回复:0
按钮状态--代码设定
更多 发布于:2012-09-06 13:52
[java]采用xml写出来的效果皆可以用代码来实现,下面的代码就是通过代码编写来实现view的状态的切换效果。
      采用xml写出来的效果皆可以用代码来实现,下面的代码就是通过代码编写来实现view的状态的切换效果。[java]    public void setPressedBg(View view, Drawable normal,Drawable focused, Drawable pressed) {
    StateListDrawable bg = new StateListDrawable();
    int[][] states = new int[6][];
    states[0] = new int[] { Android.R.attr.state_pressed, Android.R.attr.state_enabled };
           states[1] = new int[] { Android.R.attr.state_enabled, Android.R.attr.state_focused };
           states[2] = new int[] { Android.R.attr.state_enabled };
           states[3] = new int[] { Android.R.attr.state_focused ,Android.R.attr.state_window_focused};
           states[4] = new int[] { Android.R.attr.state_window_focused };
    bg.addState(states[0], pressed);
    bg.addState(states[3], focused);
    bg.addState(states[2], normal);
   view.setBackgroundDrawable(bg);
