阅读:1955回复:0
android初级之Android获取网页数据的方法总结
更多 发布于:2012-09-06 13:52
本文总结了三种获取网页数据的代码,是自己在用的时候随手整理出来的。此处仅贴出函数段,不贴出import了,用的时候可以用eclipse自动import一下就行了。函数的详细用途描述请看代码中注释。调用的时候请对应函数需要的参数。
//第一种
/**获取参数(ArrayList<NameValuePair> nameValuePairs,String url)后post给远程服务器
* 将获得的返回结果(String)返回给调用者
* 本函数适用于查询数量较少的时候
public String posturl(ArrayList<NameValuePair> nameValuePairs,String url){
    String result ="";
    String tmp="";
    InputStream is =null;
    try{
        HttpClient httpclient =new DefaultHttpClient();
        HttpPost httppost =new HttpPost(url);
        httppost.setEntity(newUrlEncodedFormEntity(nameValuePairs));
        HttpResponse response = httpclient.execute(httppost);
        HttpEntity entity = response.getEntity();
        is = entity.getContent();
    }catch(Exception e){
        return"Fail to establish http connection!";
    try{
        BufferedReader reader =new BufferedReader(newInputStreamReader(is,"utf-8"));
        StringBuilder sb =new StringBuilder();
        String line =null;
        while((line = reader.readLine()) != null) {
            sb.append(line +"\n");
        is.close();
        tmp=sb.toString();
        return"Fail to convert net stream!";
    try{
        JSONArray jArray =new JSONArray(tmp);
        for(inti=0;i<jArray.length();i++){
            JSONObject json_data = jArray.getJSONObject(i);
            Iterator<?> keys=json_data.keys();
            while(keys.hasNext()){
                result += json_data.getString(keys.next().toString());
    }catch(JSONException e){
        return"The URL you post is wrong!";
    returnresult;
//第二种
/**获取参数指定的网页代码,将其返回给调用者,由调用者对其解析
* 返回String
public String posturl(String url){
    String result ="";
    try{
        return"Fail to establish http connection!"+e.toString();
    try{
        String line =null;
        is.close();
        result=sb.toString();
    returnresult;
//第三种
/**获取指定地址的网页数据
* 返回数据流 www.atcpu.com
public InputStream streampost(String remote_addr){
    URL infoUrl =null;
    InputStream inStream =null;
    try{
        infoUrl =new URL(remote_addr);
        URLConnection connection = infoUrl.openConnection();
        HttpURLConnection httpConnection = (HttpURLConnection)connection;
        intresponseCode = httpConnection.getResponseCode();
        if(responseCode == HttpURLConnection.HTTP_OK){
            inStream = httpConnection.getInputStream();
    }catch (MalformedURLException e) {
        // TODO Auto-generated catch block
        e.printStackTrace();
    }catch (IOException e) {
    returninStream;
摘自 虚怀若谷
