阅读:2289回复:0
android sd卡读取数据库
更多 发布于:2012-09-06 13:53
先在 Manifest 里添加权限
<uses-permission Android:name="Android.permission.WRITE_EXTERNAL_STORAGE" />
<uses-permission Android:name="Android.permission.MOUNT_UNMOUNT_FILESYSTEMS" />
然后在 mainActivity 添加方法
    SQLiteDatabase db;
    private final String DATABASE_PATH = Android.os.Environment
            .getExternalStorageDirectory().getAbsolutePath() + "/vote";
    private String DATABASE_FILENAME = "db_vote.db";
// 初始化数据库
    private SQLiteDatabase openDatabase() {
        try {
            String databaseFilename = DATABASE_PATH + "/" + DATABASE_FILENAME;
            File dir = new File(DATABASE_PATH);
            if (!dir.exists())
                dir.mkdir();
            if (!(new File(databaseFilename)).exists()) {
                InputStream is = getResources().openRawResource(R.raw.db_vote);
                FileOutputStream fos = new FileOutputStream(databaseFilename);
                byte[] buffer = new byte[8192];
                int count = 0;
                while ((count = is.read(buffer)) > 0) {
                    fos.write(buffer, 0, count);
                fos.close();
                is.close();
            db = SQLiteDatabase.openOrCreateDatabase(databaseFilename, null);
            return db;
        } catch (Exception e) {
            e.printStackTrace();
        return null;
