阅读:2427回复:0
android添加文本内容到sqlite表中
更多 发布于:2012-09-06 13:53
第一步: 创建表
CREATE TABLE DLION (
    _id        INTEGER PRIMARY KEY AUTOINCREMENT,
    content    TEXT,
    questionId INTEGER,
    answerId   INTEGER,
    [right]    INTEGER
第二步: 把编辑文本内容并放到 res/raw/test.txt
  用 Notepad++ 打开,把每一个将要放在表中单元格的内容放一行
    去除行尾空格和空白行:按CTRL+H 选择正则表达式-- 查找目标:\s+$ 替换为空
    去除行首空格:按CTRL+H 选择正则表达式-- 查找目标:^\s+ 替换为空
第三步: 打开数据库 详情参照
  Android sd卡读取数据库
第四步: 添加数据到表
public void addContent() {
        try {
            BufferedReader localBufferReader = new BufferedReader(
                    new InputStreamReader(getResources().openRawResource(
                            R.raw.test)));
            db = openDatabase();
            for (int i = length + 1;; i++) {
                // 添加问题到数据库
                String questionStr = localBufferReader.readLine();
                if (questionStr == null) {
                    localBufferReader.close();
                    db.close();
                    break;
                Log.v("insert", "insert questionContent " + questionStr
                        + " success!");
                db.execSQL("insert into DLION(questionId,content) values(" + i
                        + ",'" + questionStr + "')");
                // 添加答案1到数据库
                String answerStr1 = localBufferReader.readLine();
                if (answerStr1 == null) {
                    db.close();
                    break;
                Log.v("insert", "insert answerContent1 " + answerStr1
                        + " success!");
                db.execSQL("insert into DLION(answerId,content) values(" + i
                        + ",'" + answerStr1 + "')");
                // 添加答案2到数据库 www.atcpu.com
                String answerStr2 = localBufferReader.readLine();
                if (answerStr2 == null) {
                    db.close();
                    break;
                Log.v("insert", "insert answerContent2 " + answerStr2
                        + " success!");
                ContentValues answerContent2 = new ContentValues();
                answerContent2.put("answerId", i);
                answerContent2.put("content", answerStr2);
                db.insert("DLION", "_id", answerContent2);
                // 添加答案3到数据库
                String answerStr3 = localBufferReader.readLine();
                if (answerStr3 == null) {
                    db.close();
                    break;
                Log.v("insert", "insert answerContent3 " + answerStr3
                        + " success!");
                ContentValues answerContent3 = new ContentValues();
                answerContent3.put("answerId", i);
                answerContent3.put("content", answerStr3);
                db.insert("DLION", "_id", answerContent3);
                // 添加答案4到数据库
                String answerStr4 = localBufferReader.readLine();
                if (answerStr4 == null) {
                    db.close();
                    break;
                Log.v("insert", "insert answerContent4 " + answerStr4
                        + " success!");
                ContentValues answerContent4 = new ContentValues();
                answerContent4.put("answerId", i);
                answerContent4.put("content", answerStr4);
                db.insert("DLION", "_id", answerContent4);
        } catch (Exception e) {
            // TODO: handle exception
            e.printStackTrace();
