阅读:2045回复:0
Android实现桌面歌词(类似TTPlayer)
更多 发布于:2012-09-06 13:53
Android中将Window分成多个级别。要想实现桌面歌词效果只要将Window的级别高于桌面的Window级别就行了,同时也具备可自由移动的悬浮窗口效果。下面看看代码:
package com.orgcent.desktop;
import Android.app.Application;
import Android.content.Context;
import Android.view.LayoutInflater;
import Android.view.MotionEvent;
import Android.view.View;
import Android.view.WindowManager;
import Android.view.View.OnTouchListener;
public class BaseAppliction extends Application {
    WindowManager mWM;
    WindowManager.LayoutParams mWMParams;
    @Override
    public void onCreate() {
        mWM =(WindowManager)getSystemService(Context.WINDOW_SERVICE);
        final View win = LayoutInflater.from(this).inflate(R.layout.ctrl_window, null);
        win.setOnTouchListener(new OnTouchListener() {
            float lastX, lastY;
            public boolean onTouch(View v, MotionEvent event) {
                final int action = event.getAction();
                float x = event.getX();
                float y = event.getY();
                if(action == MotionEvent.ACTION_DOWN) {
                    lastX = x;
                    lastY = y;
                } else if(action == MotionEvent.ACTION_MOVE) {
                    mWMParams.x += (int) (x - lastX);
                    mWMParams.y += (int) (y - lastY);
                    mWM.updateViewLayout(win, mWMParams);
                return true;
    WindowManager wm = mWM;
        WindowManager.LayoutParams wmParams = new WindowManager.LayoutParams();
        mWMParams = wmParams;
        wmParams.type = 2002;  //type是关键,这里的2002表示系统级窗口,你也可以试试2003。
        wmParams.format=1;
        wmParams.flags= 40;
        wmParams.width = 300;
        wmParams.height = 200;
        wm.addView(win, wmParams);
   Android:background="#ffffff"
   Android:orientation="vertical"
   Android:padding="5dp" >
    <TextView
       Android:gravity="center"
       Android:textColor="#000000" Android:text="我爱加上双方随即封锁酸辣粉丝激发了http://orgcent.com"/>
</LinearLayout>
Demo下载地址:http://code.google.com/p/android-custom-view/downloads/list
