阅读:2884回复:0
Android开发相关:(06)快速了解SQLite
更多 发布于:2012-09-06 13:54
[sql] // Set the column headers to show in the tool
sqlite>. headers on
// select all rows from a table
select * from table1;
// count the number of rows in a table
select count(*) from table1;
// select a specific set of columns
select col1, col2 from table1;
// select distinct values in a column
select distinct col1 from table1;
// counting the distinct valus
select count(col1) from (select distinct col1 from table1);
// group by
select count(*), col1 from table1 group by col1;
// regular inner join
select * from table1 t1, table2 t2 where t1.col1 = t2.col1;
// left outer join
// give me everything in t1 even though there are no rows in t2
select * from table t1 left outer join table2 t2 on t1.col1 = t2.col1 where ....
sqlite>. headers on
// group by
// left outer join
