阅读:2052回复:0
安装当前目录下所有apk的脚本
更多 发布于:2012-09-06 13:54
今天要安装几十个apk,就写了个脚本,递归查找当前目录下所有的apk文件,找到一个安装一个。
安装环境:ubuntu10.04LTS + python2.6.5
1. 打开Android设备“USB调试”
2. 重启ADB: $sudo adb kill-server
                          $sudo adb start-server
3写脚本findAndInstall.py:
[python]
#-*- coding: cp936 -*-
''''' search apk and install under current folder and sub-folders
    PythonVersion: 2.6
__author__ = "Herbert dai wen yuan"
__version__ = "$Revision: 1.0 $"
__date__ = "$Date: 2012-4-24$"
__copyright__ = "Copyright (c) 2012 HowFun"
__license__ = "Python 2.x"
import os
PATH = "./"
def findToInstall(filePath, level):
    for item in os.listdir(filePath):
        print(item + '\n');
        curItem = filePath + '/' + item
        if os.path.isdir(curItem):
            print("Enter folder: " + curItem);
            findToInstall(curItem, level + 1)
        elif os.path.isfile(curItem):
            if (".apk" == os.path.splitext(item)[1]):
                print("installing " + item + "......");
                os.system("sudo adb install " + curItem.replace(" ", "\ "));
if __name__ == "__main__":
    print ("Start install>>>>>>>>>>>>>>>>>>>\n");
    findToInstall(PATH, 0)
    print ("Install Finished>>>>>>>>>>>>>>>>>>>\n");
4.运行脚本:$sudo python findAndInstall.py
