阅读:2299回复:0
android调用照相功能
更多 发布于:2012-09-06 13:54
public class MyCameraActivity extends Activity {
    @Override
        Button btnCamera = (Button) findViewById(R.id.btnCamera);
        btnCamera.setOnClickListener(new OnClickListener() {
            @Override
            public void onClick(View v) {
                // TODO Auto-generated method stub
                letCamera();
    protected void onActivityResult(int requestCode, int resultCode, Intent data) {
        super.onActivityResult(requestCode, resultCode, data);
        switch (requestCode) {
        case 1:// 拍照
            if (resultCode == RESULT_OK) {
                Toast.makeText(this, "拍摄成功", Toast.LENGTH_SHORT).show();
            break;
        default:
            break;
    protected void letCamera() {
        Intent imageCaptureIntent = new Intent(MediaStore.ACTION_IMAGE_CAPTURE);
        String strImgPath = Environment.getExternalStorageDirectory()
                .toString() + "/dlion/";// 存放照片的文件夹
        String fileName = new SimpleDateFormat("yyyyMMddHHmmss")
                .format(new Date()) + ".jpg";// 照片命名
        File out = new File(strImgPath);
        if (!out.exists()) {
            out.mkdirs();
        out = new File(strImgPath, fileName);
        strImgPath = strImgPath + fileName;// 该照片的绝对路径
        Uri uri = Uri.fromFile(out);
        imageCaptureIntent.putExtra(MediaStore.EXTRA_OUTPUT, uri);
        imageCaptureIntent.putExtra(MediaStore.EXTRA_VIDEO_QUALITY, 1);
        startActivityForResult(imageCaptureIntent, 1);
