Android api demo里面有一个编写高效list adapter的demo,里面写了建议的两条高效原则
1. 在getView方法中,重复利用 convertView,convertView是旧的View,建议先判断是否为空,如果不为空,可以修改其内容来显示新的row。
public View getView(int position, View convertView, ViewGroup parent) {
SpeechView sv;
if (convertView == null) {
sv = new SpeechView(mContext, mTitles[position],
mDialogue[position]);
} else {
sv = (SpeechView) convertView;
sv.setTitle(mTitles[position]);
sv.setDialogue(mDialogue[position]);
return sv;
2. 在getView方法中,利用ViewHolder来保存与convertView相关联的子View,避免调用 findViewById方法,以提高效率
// A ViewHolder keeps references to children views to avoid unneccessary calls
// to findViewById() on each row.
ViewHolder holder;
// When convertView is not null, we can reuse it directly, there is no need
// to reinflate it. We only inflate a new View when the convertView supplied
// by ListView is null.
convertView = mInflater.inflate(R.layout.list_item_icon_text, null);
// Creates a ViewHolder and store references to the two children views
// we want to bind data to.
holder = new ViewHolder();
holder.text = (TextView) convertView.findViewById(R.id.text);
holder.icon = (ImageView) convertView.findViewById(R.id.icon);
convertView.setTag(holder);
} else {
// Get the ViewHolder back to get fast access to the TextView
// and the ImageView.
holder = (ViewHolder) convertView.getTag();
holder.text.setText(DATA[position]);
holder.icon.setImageBitmap((position ; 1) == 1 ? mIcon1 : mIcon2);
return convertView;
