阅读:4487回复:0
Android实战技巧:多线程AsyncTask
更多 发布于:2012-09-06 13:58
Understanding AsyncTask
AsyncTask是Android 1.5 Cubake加入的用于实现异步操作的一个类,在此之前只能用java SE库中的Thread来实现多线程异步,AsyncTask是Android平台自己的异步工具,融入了Android平台的特性,让异步操作更加的安全,方便和实用。实质上它也是对java SE库中Thread的一个封装,加上了平台相关的特性,所以对于所有的多线程异步都强烈推荐使用AsyncTask,因为它考虑,也融入了Android平台的特性,更加的安全和高效。
AsyncTask可以方便的执行异步操作(doInBackground),又能方便的与主线程进行通信,它本身又有良好的封装性,可以进行取消操作(cancel())。关于AsyncTask的使用,文档说的很明白,下面直接上实例。
实例
这个实例用AsyncTask到网络上下载图片,同时显示进度,下载完图片更新UI。
[java]
package com.hilton.effectiveAndroid.concurrent;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.MalformedURLException;
import java.net.URL;
import Android.app.Activity;
import Android.content.Context;
import Android.graphics.Bitmap;
import Android.graphics.BitmapFactory;
import Android.os.AsyncTask;
import Android.os.Bundle;
import Android.os.SystemClock;
import Android.view.View;
import Android.widget.Button;
import Android.widget.ImageView;
import Android.widget.ProgressBar;
import com.hilton.effectiveAndroid.R;
* AsyncTask cannot be reused, i.e. if you have executed one AsyncTask, you must discard it, you cannot execute it again.
* If you try to execute an executed AsyncTask, you will get "java.lang.IllegalStateException: Cannot execute task: the task is already running"
* In this demo, if you click "get the image" button twice at any time, you will receive "IllegalStateException".
* About cancellation:
* You can call AsyncTask#cancel() at any time during AsyncTask executing, but the result is onPostExecute() is not called after
* doInBackground() finishes, which means doInBackground() is not stopped. AsyncTask#isCancelled() returns true after cancel() getting
* called, so if you want to really cancel the task, i.e. stop doInBackground(), you must check the return value of isCancelled() in
* doInBackground, when there are loops in doInBackground in particular.
* This is the same to java threading, in which is no effective way to stop a running thread, only way to do is set a flag to thread, and check
* the flag every time in Thread#run(), if flag is set, run() aborts.
public class AsyncTaskDemoActivity extends Activity {
    private static final String ImageUrl = "http://www.atcpu.com/uploadfile/2012/0515/20120515100913728.jpg";
    private ProgressBar mProgressBar;
    private ImageView mImageView;
    private Button mGetImage;
    private Button mAbort;
    @Override
    public void onCreate(Bundle icicle) {
    super.onCreate(icicle);
    setContentView(R.layout.async_task_demo_activity);
    mProgressBar = (ProgressBar) findViewById(R.id.async_task_progress);
    mImageView = (ImageView) findViewById(R.id.async_task_displayer);
    final ImageLoader loader = new ImageLoader();
    mGetImage = (Button) findViewById(R.id.async_task_get_image);
    mGetImage.setOnClickListener(new View.OnClickListener() {
        public void onClick(View v) {
        loader.execute(ImageUrl);
    mAbort = (Button) findViewById(R.id.asyc_task_abort);
    mAbort.setOnClickListener(new View.OnClickListener() {
        loader.cancel(true);
    mAbort.setEnabled(false);
    private class ImageLoader extends AsyncTask<String, Integer, Bitmap> {
    private static final String TAG = "ImageLoader";
    @Override
    protected void onPreExecute() {
        // Initialize progress and image
        mGetImage.setEnabled(false);
        mAbort.setEnabled(true);
        mProgressBar.setVisibility(View.VISIBLE);
        mProgressBar.setProgress(0);
        mImageView.setImageResource(R.drawable.icon);
    @Override
    protected Bitmap doInBackground(String... url) {
         * Fucking ridiculous thing happened here, to use any internet connections, either via HttpURLConnection
         * or HttpClient, you must declare INTERNET permission in AndroidManifest.xml. Otherwise you will get
         * "UnknownHostException" when connecting or other tcp/ip/http exceptions rather than "SecurityException"
         * which tells you need to declare INTERNET permission.
        try {
        URL u;
        HttpURLConnection conn = null;
        InputStream in = null;
        OutputStream out = null;
        final String filename = "local_temp_image";
        try {
            u = new URL(url[0]);
            conn = (HttpURLConnection) u.openConnection();
            conn.setDoInput(true);
            conn.setDoOutput(false);
            conn.setConnectTimeout(20 * 1000);
            in = conn.getInputStream();
            out = openFileOutput(filename, Context.MODE_PRIVATE);
            byte[] buf = new byte[8196];
            int seg = 0;
            final long total = conn.getContentLength();
            long current = 0;
             * Without checking isCancelled(), the loop continues until reading whole image done, i.e. the progress
             * continues go up to 100. But onPostExecute() will not be called.
             * By checking isCancelled(), we can stop immediately, i.e. progress stops immediately when cancel() is called.
            while (!isCancelled() ;; (seg = in.read(buf)) != -1) {
            out.write(buf, 0, seg);
            current += seg;
            int progress = (int) ((float) current / (float) total * 100f);
            publishProgress(progress);
            SystemClock.sleep(1000);
        } finally {
            if (conn != null) {
            conn.disconnect();
            if (in != null) {
            in.close();
            if (out != null) {
            out.close();
        return BitmapFactory.decodeFile(getFileStreamPath(filename).getAbsolutePath());
        } catch (MalformedURLException e) {
        e.printStackTrace();
        } catch (IOException e) {
        return null;
    @Override
    protected void onProgressUpdate(Integer... progress) {
        mProgressBar.setProgress(progress[0]);
    @Override
    protected void onPostExecute(Bitmap image) {
        if (image != null) {
        mImageView.setImageBitmap(image);
        mProgressBar.setProgress(100);
        mProgressBar.setVisibility(View.GONE);
运行结果
先后顺序分别是下载前,下载中和下载后
总结
关于怎么使用看文档和这个例子就够了,下面说下,使用时的注意事项:
1. AsyncTask对象不可重复使用,也就是说一个AsyncTask对象只能execute()一次,否则会有异常抛出"java.lang.IllegalStateException: Cannot execute task: the task is already running"
2. 在doInBackground()中要检查isCancelled()的返回值,如果你的异步任务是可以取消的话。
cancel()仅仅是给AsyncTask对象设置了一个标识位,当调用了cancel()后,发生的事情只有:AsyncTask对象的标识位变了,和doInBackground()执行完成后,onPostExecute()不会被回调了,而doInBackground()和onProgressUpdate()还是会继续执行直到doInBackground()结束。所以要在doInBackground()中不断的检查isCancellled()的返回值,当其返回true时就停止执行,特别是有循环的时候。如上面的例子,如果把读取数据的isCancelled()检查去掉,图片还是会下载,进度也一直会走,只是最后图片不会放到UI上(因为onPostExecute()没被回调)!
这里的原因其实很好理解,想想java SE的Thread吧,是没有方法将其直接Cacncel掉的,那些线程取消也无非就是给线程设置标识位,然后在run()方法中不断的检查标识而已。
3. 如果要在应用程序中使用网络,一定不要忘记在AndroidManifest中声明INTERNET权限,否则会报出很诡异的异常信息,比如上面的例子,如果把INTERNET权限拿掉会抛出"UnknownHostException"。刚开始很疑惑,因为模拟器是可以正常上网的,后来google了下才发现原来是没权限,但是疑问还是没有消除,既然没有声明网络权限,为什么不直接提示无网络权限呢?
对比java SE的Thread
Thread是非常原始的类,它只有一个run()方法,一旦开始,无法停止,它仅适合于一个非常独立的异步任务,也即不需要与主线程交互,对于其他情况,比如需要取消或与主线程交互,都需添加额外的代码来实现,并且还要注意同步的问题。
而AsyncTask是封装好了的,可以直接拿来用,如果你仅执行独立的异步任务,可以仅实现doInBackground()。
所以,当有一个非常独立的任务时,可以考虑使用Thread,其他时候,尽可能的用AsyncTask。
摘自 浪人的星空
