阅读:2430回复:0
android webview and javascript交互
更多 发布于:2012-09-06 13:59
方法一:
*javascript in html:
<SCRIPT  LANGUAGE="javaScript">
function checkOrientation(){
alert(window.orientation);
window.addEventListener('onorientationchange' in window ? 'orientationchange' : 'resize', checkOrientation, false);
function print() {
window.location="print://print";
function setting() {
window.location="setting://setting";
</SCRIPT>
*java code:
        public boolean shouldOverrideUrlLoading(webView view, String url) {
            AppUtils.LogD(url);
            if (url.startsWith("mailto:")) {
                MailTo mt = MailTo.parse(url);
                Intent i = AppUtils.newEmailIntent(activity, mt.getTo(),
                        mt.getSubject(), mt.getBody(), mt.getCc());
                activity.startActivity(i);
                view.reload();
                return true;
            } else if (url.startsWith("print://print")) {
                // show toast message for print button
                Toast.makeText(activity, R.string.print_button_alert,
                        Toast.LENGTH_LONG).show();
                return true;
            } else if (url.startsWith("setting://setting")) {
                // show setting dialog
                ((DetailViewControlerImpl) activity).openSettingsPage();
                return true;
            } else {
                return false;
方法二:
javascript in html(mypage):
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<HTML>
<HEAD>
<TITLE>Actuate Viewer</TITLE>
<script type="text/javascript">
    function change() {
        document.getElementById("changePhoto").src = "http://www.atcpu.com/uploadfile/2012/0519/20120519094025145.png";
</script>
</HEAD>
<BODY>
    <a> <img id="changePhoto"
        src="http://www.atcpu.com/uploadfile/2012/0519/20120519094025304.png" /><br> Click me! </a>
</BODY>
</HTML>
java code:
    mWebView.addjavascriptinterface(new MyjavaScriptInterface(), "mypage");
    final class MyjavaScriptInterface {
        public MyjavaScriptInterface() {
        public void clickOnAndroid() {
            mHandler.post(new Runnable() {
                @Override
                public void run() {
                    mWebView.loadUrl("javascript:change()");
