阅读:1707回复:0
android横竖屏切换与数据保存
更多 发布于:2012-09-06 13:59
一,横竖屏切换时不重新载入数据,只需在menifest中加入:
Android:configChanges="keyboardHidden|orientation"
二,横竖屏切换时重新载入数据,程序会程序进入onCreate,因此需要对数据进行存储以备后用。
***方法一:
    @Override
    public Object onRetainNonConfigurationInstance() {
        // save data :browserHistoryAdapter
        Intent i = new Intent();
        Bundle b = new Bundle();
        b.putSerializable(KEY_HISTORY_SAVED, (Serializable) browserHistoryAdapter);
        i.putExtras(b);
        return i;
        // get saved data after configure changed :browserHistoryAdapter
        Intent historySaved;
        if((historySaved = (Intent) getLastNonConfigurationInstance()) == null){
            historySaved = getIntent();
        if(historySaved != null ;; historySaved.getExtras() != null){
            browserHistoryAdapter = (BrowserHistoryAdapter) historySaved.getExtras().get(KEY_HISTORY_SAVED);
***方法二:
    @Override
    protected void onSaveInstanceState(Bundle outState) {
        super.onSaveInstanceState(outState);
        // save data :url
        outState.putString(STR_URL, url);
        // get saved data after configure changed :url
        if (savedInstanceState != null) {
            url = savedInstanceState.getString(STR_URL);
