阅读:2100回复:0
android launch初探
更多 发布于:2012-09-06 13:59
1. manifest:
需要加上这两个category:
              <category Android:name="Android.intent.category.DEFAULT" />
                <category Android:name="Android.intent.category.HOME" />
2. main activity:
package com.mylauncher;
import java.util.Collections;
import java.util.List;
import Android.app.Activity;
import Android.app.AlertDialog;
import Android.content.ComponentName;
import Android.content.Dialoginterface;
import Android.content.DialogInterface.OnClickListener;
import Android.content.Intent;
import Android.content.pm.PackageManager;
import Android.content.pm.ResolveInfo;
import Android.net.Uri;
import Android.os.Bundle;
import Android.view.View;
import Android.widget.AdapterView;
import Android.widget.AdapterView.OnItemClickListener;
import Android.widget.AdapterView.OnItemLongClickListener;
import Android.widget.GridView;
public class D_MyLauncherActivity extends Activity implements
OnItemClickListener, OnItemLongClickListener {
private GridView mGridView;
private List<ResolveInfo> apps;
@Override
PackageManager manager = this.getPackageManager();
Intent mainIntent = new Intent(Intent.ACTION_MAIN, null);
mainIntent.addCategory(Intent.CATEGORY_LAUNCHER);
apps = manager.queryIntentActivities(mainIntent, 0);
Collections.sort(apps, new ResolveInfo.DisplayNameComparator(manager));
mGridView = (GridView) findViewById(R.id.gridView1);
mGridView.setAdapter(new MyGridViewAdapter(this, apps));
mGridView.setOnItemClickListener(this);
mGridView.setOnItemLongClickListener(this);
@Override
public void onItemClick(AdapterView<?> arg0, View arg1, int position,
long arg3) {
ResolveInfo app = apps.get(position);
Intent i = new Intent(Intent.ACTION_MAIN);
i.setComponent(new ComponentName(app.activityInfo.packageName,
app.activityInfo.name));
startActivity(i);
@Override
public boolean onItemLongClick(AdapterView<?> arg0, View arg1,
int position, long arg3) {
final ResolveInfo app = apps.get(position);
new AlertDialog.Builder(this)
.setMessage(
"Remove " + app.loadLabel(getPackageManager())
+ " from your device?")
.setPositiveButton("OK", new OnClickListener() {
@Override
public void onClick(DialogInterface dialog, int which) {
Uri uri = Uri.fromParts("package",
app.activityInfo.packageName, null);
Intent it = new Intent(Intent.ACTION_DELETE, uri);
startActivity(it);
}).setNegativeButton("Cancel", new OnClickListener() {
@Override
}).show();
return false;
3. adapter:
import Android.content.Context;
import Android.view.LayoutInflater;
import Android.view.ViewGroup;
import Android.widget.BaseAdapter;
import Android.widget.ImageView;
import Android.widget.TextView;
public class MyGridViewAdapter extends BaseAdapter {
private LayoutInflater mInflater;
private Context context;
public MyGridViewAdapter(Context c, List<ResolveInfo> apps) {
mInflater = LayoutInflater.from(c);
this.apps = apps;
this.context = c;
private class ViewHolder {
private ImageView appIcon;
private TextView appName;
@Override
public int getCount() {
return apps.size();
@Override
public Object getItem(int position) {
return apps.get(position);
@Override
public long getItemId(int position) {
return position;
@Override
public View getView(int position, View convertView, ViewGroup parent) {
View view = convertView;
if (view == null) {
view = mInflater.inflate(R.layout.app_shortcut, null);
ViewHolder viewHolder = new ViewHolder();
viewHolder.appIcon = (ImageView) view.findViewById(R.id.imageView1);
viewHolder.appName = (TextView) view.findViewById(R.id.textView1);
view.setTag(viewHolder);
ViewHolder holder = (ViewHolder) view.getTag();
holder.appIcon.setBackgroundDrawable(app.loadIcon(context.getPackageManager()));
holder.appName.setText(app.loadLabel(context.getPackageManager()));
return view;
摘自 fhy_2008的专栏
