阅读:6265回复:0
Android SurfaceView 详解(三)
更多 发布于:2012-09-06 14:01
SurfaceView 示波器的例子:直接上代码了就
该程序会根据单击的按钮在屏幕上自动绘制正弦波和余弦波形。程序每次绘制时只需要绘制(更新)当前点的波形,前面已经绘制的波形无须更新,利用了SurfaceHolder的lockCanvas(Rect r)方法
1.布局文件Layout/show_wave.xml:
[html]
<LinearLayout
  xmlns:Android="http://schemas.Android.com/apk/res/Android"
  Android:orientation ="vertical"
  Android:layout_width="wrap_content"
  Android:layout_height="wrap_content">
  <Button
  Android:id="@+id/sin"
  Android:text="正弦曲线"
  <Button
  Android:id="@+id/cos"
  Android:text="余弦曲线"
  <SurfaceView
  Android:id="@+id/show"
</LinearLayout>
2.主界面Activity:ShowWave
[java]
package com.infy.configuration;
import java.util.Timer;
import java.util.TimerTask;
import Android.app.Activity;
import Android.graphics.Canvas;
import Android.graphics.Color;
import Android.graphics.Paint;
import Android.graphics.Rect;
import Android.os.Bundle;
import Android.view.SurfaceHolder;
import Android.view.SurfaceView;
import Android.view.View;
import Android.view.SurfaceHolder.Callback;
import Android.view.View.OnClickListener;
import Android.widget.Button;
public class ShowWave extends Activity{
    private SurfaceHolder holder;
    private Paint paint;
    final int HEIGHT=320;
    final int WIDTH=320;
    final int X_OFFSET = 5;
    private int cx = X_OFFSET;
    //实际的Y轴的位置
    int centerY = HEIGHT /2;
    Timer timer = new Timer();
    TimerTask task = null;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        // TODO Auto-generated method stub
        setContentView(R.layout.show_wave);
        final SurfaceView surface = (SurfaceView)findViewById(R.id.show);
        //初始化SurfaceHolder对象 www.atcpu.com
        holder = surface.getHolder();
        paint = new Paint();
        paint.setColor(Color.GREEN);
        paint.setStrokeWidth(3);
        Button sin =(Button)findViewById(R.id.sin);
        Button cos =(Button)findViewById(R.id.cos);
        OnClickListener listener = (new OnClickListener() {
            @Override
            public void onClick(final View source) {
            drawBack(holder);
            cx = X_OFFSET;
            if(task != null){
                task.cancel();
            task = new TimerTask() {
                @Override
                public void run() {
                    int cy = source.getId() == R.id.sin ? centerY -(int)(100 * Math.sin((cx -5) *2 * Math.PI/150)):
                                   centerY -(int)(100 * Math.cos((cx-5)*2*Math.PI/150));
                    Canvas canvas = holder.lockCanvas(new Rect(cx,cy-2,cx+2,cy+2));
                    canvas.drawPoint(cx, cy, paint);
                    cx++;
                    if(cx >WIDTH){
                        task.cancel();
                        task = null;
                    holder.unlockCanvasAndPost(canvas);
            timer.schedule(task, 0,30);
        sin.setOnClickListener(listener);
        cos.setOnClickListener(listener);
        holder.addCallback(new Callback() {
            public void surfaceChanged(SurfaceHolder holder,int format,int width,int height){
                drawBack(holder);
            @Override
            public void surfaceCreated(SurfaceHolder holder) {
            @Override
            public void surfaceDestroyed(SurfaceHolder holder) {
            timer.cancel();
    private void drawBack(SurfaceHolder holder){
        Canvas canvas = holder.lockCanvas();
        //绘制白色背景
        canvas.drawColor(Color.WHITE);
        Paint p = new Paint();
        p.setColor(Color.BLACK);
        p.setStrokeWidth(2);
        //绘制坐标轴
        canvas.drawLine(X_OFFSET, centerY, WIDTH, centerY, p);
        canvas.drawLine(X_OFFSET, 40, X_OFFSET, HEIGHT, p);
        holder.lockCanvas(new Rect(0,0,0,0));
3.最后显示结果:
a.正弦曲线
b.余弦曲线:
摘自 Damon_tong的专栏
