阅读:3019回复:0
Android获取系统cpu信息,内存,版本,电量等信息
更多 发布于:2012-09-06 14:02
1、cpu频率,CPU信息:/proc/cpuinfo和/proc/stat
通过读取文件/proc/cpuinfo系统CPU的类型等多种信息。
读取/proc/stat 所有CPU活动的信息来计算CPU使用率
下面我们就来讲讲如何通过代码来获取CPU频率:
package com.orange.cpu;
import java.io.BufferedReader;
import java.io.FileNotFoundException;
import java.io.FileReader;
import java.io.IOException;
import java.io.InputStream;
public class CpuManager {
        // 获取CPU最大频率(单位KHZ)
     // "/system/bin/cat" 命令行
     // "/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq" 存储最大频率的文件的路径
        public static String getMaxCpuFreq() {
                String result = "";
                ProcessBuilder cmd;
                try {
                        String[] args = { "/system/bin/cat",
                                        "/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq" };
                        cmd = new ProcessBuilder(args);
                        Process process = cmd.start();
                        InputStream in = process.getInputStream();
                        byte[] re = new byte[24];
                        while (in.read(re) != -1) {
                                result = result + new String(re);
                        in.close();
                } catch (IOException ex) {
                        ex.printStackTrace();
                        result = "N/A";
                return result.trim();
         // 获取CPU最小频率(单位KHZ)
        public static String getMinCpuFreq() {
                String result = "";
                ProcessBuilder cmd;
                try {
                                        "/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq" };
                        in.close();
                        result = "N/A";
         // 实时获取CPU当前频率(单位KHZ)
        public static String getCurCpuFreq() {
                String result = "N/A";
                try {
                        FileReader fr = new FileReader(
                                        "/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq");
                        BufferedReader br = new BufferedReader(fr);
                        String text = br.readLine();
                        result = text.trim();
                } catch (FileNotFoundException e) {
                        e.printStackTrace();
                } catch (IOException e) {
                return result;
        // 获取CPU名字
        public static String getCpuName() {
                try {
                        FileReader fr = new FileReader("/proc/cpuinfo");
                        String[] array = text.split(":\\s+", 2);
                        for (int i = 0; i < array.length; i++) {
                        return array[1];
                return null;
2、内存:/proc/meminfo
public void getTotalMemory() {
        String str1 = "/proc/meminfo";
        String str2="";
        try {
            FileReader fr = new FileReader(str1);
            BufferedReader localBufferedReader = new BufferedReader(fr, 8192);
            while ((str2 = localBufferedReader.readLine()) != null) {
                Log.i(TAG, "---" + str2);
3、Rom大小 www.atcpu.com
public long[] getRomMemroy() {
        long[] romInfo = new long[2];
        //Total rom memory
        romInfo[0] = getTotalinternalMemorySize();
        //Available rom memory
        File path = Environment.getDataDirectory();
        StatFs stat = new StatFs(path.getPath());
        long blockSize = stat.getBlockSize();
        long availableBlocks = stat.getAvailableBlocks();
        romInfo[1] = blockSize * availableBlocks;
        getVersion();
        return romInfo;
    public long getTotalInternalMemorySize() {
        long totalBlocks = stat.getBlockCount();
        return totalBlocks * blockSize;
4、sdCard大小
public long[] getSDCardMemory() {
        long[] sdCardInfo=new long[2];
        String state = Environment.getExternalStorageState();
        if (Environment.MEDIA_MOUNTED.equals(state)) {
            File sdcardDir = Environment.getExternalStorageDirectory();
            StatFs sf = new StatFs(sdcardDir.getPath());
            long bSize = sf.getBlockSize();
            long bCount = sf.getBlockCount();
            long availBlocks = sf.getAvailableBlocks();
            sdCardInfo[0] = bSize * bCount;//总大小
            sdCardInfo[1] = bSize * availBlocks;//可用大小
        return sdCardInfo;
5、电池电量
private BroadcastReceiver batteryReceiver=new BroadcastReceiver(){
        @Override
        public void onReceive(Context context, Intent intent) {
            int level = intent.getIntExtra("level", 0);
            //  level加%就是当前电量了
registerReceiver(batteryReceiver, new IntentFilter(Intent.ACTION_BATTERY_CHANGED));
6、系统的版本信息
public String[] getVersion(){
    String[] version={"null","null","null","null"};
    String str1 = "/proc/version";
    String str2;
    String[] arrayOfString;
    try {
        FileReader localFileReader = new FileReader(str1);
                localFileReader, 8192);
        str2 = localBufferedReader.readLine();
        arrayOfString = str2.split("\\s+");
        version[0]=arrayOfString[2];//KernelVersion
        localBufferedReader.close();
    version[1] = Build.VERSION.RELEASE;// firmware version
    version[2]=Build.MODEL;//model
    version[3]=Build.DISPLAY;//system version
    return version;
7、mac地址和开机时间
public String[] getOtherInfo(){
    String[] other={"null","null"};
       wifiManager wifiManager = (WifiManager) mContext.getSystemService(Context.WIFI_SERVICE);
       WifiInfo wifiInfo = wifiManager.getConnectionInfo();
       if(wifiInfo.getMacaddress()!=null){
        other[0]=wifiInfo.getMacAddress();
    } else {
        other[0] = "Fail";
    other[1] = getTimes();
       return other;
private String getTimes() {
    long ut = SystemClock.elapsedRealtime() / 1000;
    if (ut == 0) {
        ut = 1;
    int m = (int) ((ut / 60) % 60);
    int h = (int) ((ut / 3600));
    return h + " " + mContext.getString(R.string.info_times_hour) + m + " "
            + mContext.getString(R.string.info_times_minute);
摘自 brainy
