阅读:2677回复:0
android震动效果实现,从Settings里面读值
更多 发布于:2012-09-06 14:02
震动效果实现如下:
[java] if(Settings.System.getInt(getContentResolver(), Settings.System.LOCKSCREEN_SOUNDS_ENABLED, 1) != 0)
    Vibrator vibrator = (Vibrator) getSystemService("vibrator");
    vibrator.vibrate(50);
飞行模式判定:
[java] /**
* judge current airplane mode is set on
* @return
private boolean isAirplanemodeOn()
    return Settings.System.getInt(getContentResolver(), Settings.System.AIRPLANE_MODE_ON, 0) != 0;
摘自 知识空间
