阅读:3743回复:0
Android GridView中GridAdapter用法详解
更多 发布于:2012-09-06 14:03
说到GridView Listview一定会提到他的adapter,现整理如下:
main.xml布局里面:
[html] <GridView
    Android:id="@+id/grid"
    Android:columnWidth="70dp"
    Android:numColumns="auto_fit"
    Android:verticalSpacing="10dp"
    Android:horizontalSpacing="10dp"
    AndroidtretchMode="columnWidth"
    Android:gravity="center"
<GridView
gridview_item.xml:
[html] <?xml version="1.0" encoding="utf-8"?>
<FrameLayout xmlns:Android="http://schemas.Android.com/apk/res/Android"
    Android:layout_width="wrap_content"
    Android:orientation="vertical"
    Android:layout_gravity="center"
    <LinearLayout
        Android:layout_gravity="center">
        <ImageView
            Android:id="@+id/grid_icon"
            Android:layout_height="80dip"
            Android:layout_width="80dip"
        </ImageView>
        <TextView
            Android:id="@+id/grid_name"
            AndroidingleLine="true"
            Android:textSize="13px"
            Android:layout_marginTop="4dip"
        </TextView>
    </LinearLayout>
</FrameLayout>
<LinearLayout
  <ImageView
  </ImageView>
  <TextView
  </TextView>
</LinearLayout>
</FrameLayout>
java 代码:
[java] GridView grid = (GridView) findViewById(R.id.grid);
grid.setAdapter(new GridAdapter(this, mNameList, mDrawableList));
GridAdapter.java类:
[java] package com.Android.test;
import java.util.ArrayList;
import Android.content.Context;
import Android.graphics.drawable.Drawable;
import Android.view.Gravity;
import Android.view.LayoutInflater;
import Android.view.View;
import Android.view.ViewGroup;
import Android.widget.BaseAdapter;
import Android.widget.ImageView;
import Android.widget.LinearLayout;
import Android.widget.TextView;
public class GridAdapter extends BaseAdapter {
    private ArrayList<String> mNameList = new ArrayList<String>();
    private ArrayList<Drawable> mDrawableList = new ArrayList<Drawable>();
    private LayoutInflater mInflater;
    private Context mContext;
    LinearLayout.LayoutParams params;
    public GridAdapter(Context context, ArrayList<String> nameList, ArrayList<Drawable> drawableList) {
        mNameList = nameList;
        mDrawableList = drawableList;
        mContext = context;
        mInflater = LayoutInflater.from(context);
        params = new LinearLayout.LayoutParams(LinearLayout.LayoutParams.WRAP_CONTENT, LinearLayout.LayoutParams.WRAP_CONTENT);
        params.gravity = Gravity.CENTER;
    public int getCount() {
        return mNameList.size();
    public Object getItem(int position) {
        return mNameList.get(position);
    public long getItemId(int position) {
        return position;
    public View getView(int position, View convertView, ViewGroup parent) {
        ItemViewTag viewTag;
        if (convertView == null)
            convertView = mInflater.inflate(R.layout.gridview_item, null);
            // construct an item tag
            viewTag = new ItemViewTag((ImageView) convertView.findViewById(R.id.grid_icon), (TextView) convertView.findViewById(R.id.grid_name));
            convertView.setTag(viewTag);
        } else
            viewTag = (ItemViewTag) convertView.getTag();
        // set name
        viewTag.mName.setText(mNameList.get(position));
        // set icon
        viewTag.mIcon.setBackgroundDrawable(mDrawableList.get(position));
        viewTag.mIcon.setLayoutParams(params);
        return convertView;
    class ItemViewTag
        protected ImageView mIcon;
        protected TextView mName;
         * The constructor to construct a navigation view tag
         * @param name
         *            the name view of the item
         * @param size
         *            the size view of the item
         * @param icon
         *            the icon view of the item
        public ItemViewTag(ImageView icon, TextView name)
            this.mName = name;
            this.mIcon = icon;
  mContext = context;
  return position;
  } else
  // set name
  // set icon
  return convertView;
class ItemViewTag
   * @param name
   * @param size
   * @param icon
   this.mName = name;
   this.mIcon = icon;
到此,adapter的使用就算结束,效果图如下:
