阅读:2352回复:0
Android API Demos学习(4) - Receive Result
更多 发布于:2012-09-06 14:03
本例展示一个Activity怎么接受通过它打开的另外一个Activity返回的结果。
比较常见的例子是,发送短信的时候,需要打开联系人程序选择联系人,然后返回选择的信息到发送程序。
setResult()方法负责发送信息,onActivityResult()方法负责接受信息。
// Definition of the one requestCode we use for receiving resuls.
    static final private int GET_CODE = 0;
    private OnClickListener mGetListener = new OnClickListener() {
        public void onClick(View v) {
            // Start the activity whose result we want to retrieve.  The
            // result will come back with request code GET_CODE.
            Intent intent = new Intent(ReceiveResult.this, SendResult.class);
            startActivityForResult(intent, GET_CODE);
startActivityForResult方法启动我们想从那里取得信息的Activity,GET_CODE会在返回信息的时候一起返回,那样我们就通过GET_CODE出来返回的结果。
灯火电脑 www.atcpu.com
在SendResult.java中:
private OnClickListener mCorkyListener = new OnClickListener()
            // To send a result, simply call setResult() before your
            // activity is finished.
            setResult(RESULT_OK, (new Intent()).setAction("Corky!"));
            finish();
    private OnClickListener mVioletListener = new OnClickListener()
            setResult(RESULT_OK, (new Intent()).setAction("Violet!"));
            finish();
在程序停止前调用setResult方法返回结果。
@Override
protected void onActivityResult(int requestCode, int resultCode,
Intent data) {
        // You can use the requestCode to select between multiple child
        // activities you may have started.  Here there is only one thing
        // we launch.
        if (requestCode == GET_CODE) {
            // We will be adding to our text.
            Editable text = (Editable)mResults.getText();
            // This is a standard resultCode that is sent back if the
            // activity doesn't supply an explicit result.  It will also
            // be returned if the activity failed to launch.
            if (resultCode == RESULT_CANCELED) {
                text.append("(cancelled)");
            // Our protocol with the sending activity is that it will send
            // text in 'data' as its result.
            } else {
                text.append("(okay ");
                text.append(Integer.toString(resultCode));
                text.append(") ");
                if (data != null) {
                    text.append(data.getAction());
            text.append("\n");
onActivityResult方法接受返回的结果,在onResume方法前执行。三个参数的意思分别是:
1. requestCode就是startActivityForResult中的第二个参数,可以用来区分是哪一个activity发送的请求。
2. resultCode是子activity返回的code,一般为RESULT_OK和RESULT_CANCELLED。
3. data是返回的结果数据。
