阅读:2933回复:0
Android 程式开发:(二)使用意图 —— 2.4 使用Intent传递数据
更多 发布于:2012-09-06 14:03
除了能从一个Activity返回数据结果之外,向一个Activity传递数据也是很常用的。
    1.新建一个名为PassData的工程。
    2.main.xml中的代码。
[java] view plaincopy<?xml version="1.0" encoding="utf-8"?>
    <Button
        Android:id="@+id/btn_SecondActivity"
        Android:onClick="onClick"
        Android:text="Click to go to Second Activity" />
</LinearLayout>
    3.在res/layout文件夹下,创建secondactivity.xml文件。[java] view plaincopy<?xml version="1.0" encoding="utf-8"?>
    <TextView
        Android:text="Welcome to Second Activity" />
    <Button
        Android:id="@+id/btn_MainActivity"
        Android:text="Click to return to main activity" />
</LinearLayout>
    4.新建一个Activity子类:SecondActivity.java。[java] view plaincopypublic class SecondActivity extends Activity {
    @Override
        setContentView(R.layout.secondactivity);
        // ---get the data passed in using getStringExtra()---
        Toast.makeText(this, getIntent().getStringExtra("str1"),
                Toast.LENGTH_SHORT).show();
        // ---get the data passed in using getIntExtra()---
                Integer.toString(getIntent().getIntExtra("age1", 0)),
        // ---get the Bundle object passed in---
        Bundle bundle = getIntent().getExtras();
        // ---get the data using the getString()---
        Toast.makeText(this, bundle.getString("str2"), Toast.LENGTH_SHORT)
                .show();
        // ---get the data using the getInt() method---
        Toast.makeText(this, Integer.toString(bundle.getInt("age2")),
    public void onClick(View view) {
        // ---use an Intent object to return data---
        Intent i = new Intent();
        // ---use the putExtra() method to return some
        // value---
        i.putExtra("age3", 45);
        // ---use the setData() method to return some value---
        i.setData(Uri.parse("Something passed back to main activity"));
        // ---set the result with OK and the Intent object---
        setResult(RESULT_OK, i);
        // ---destroy the current activity---
        finish();
    5.AndroidManifest.xml中的代码。[java] view plaincopy<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:Android="http://schemas.Android.com/apk/res/Android"
    package="net.horsttnann.PassingData"
    Android:versionCode="1"
    Android:versionName="1.0" >
    <uses-sdk Android:minSdkVersion="10" />
    <application
        Android:icon="@drawable/ic_launcher"
        Android:label="@string/app_name" >
        <activity
            Android:name=".PassingDataActivity"
            <intent-filter>
                <action Android:name="Android.intent.action.MAIN" />
                <category Android:name="Android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity
            Android:name="net.horsttnann.PassingData.SecondActivity"
            Android:label="Second Activity" >
            <intent-filter>
                <action Android:name="net.horsttnann.PassingDataSecondActivity" />
                <category Android:name="Android.intent.category.DEFAULT" />
            </intent-filter>
        </activity>
    </application>
</manifest>
    6.PassDataActivity中的代码。
[java] view plaincopyprint?public class PassingDataActivity extends Activity {
    @Override
        Intent i = new
                Intent("net.learn2develop.PassingDataSecondActivity");
        //---use putExtra() to add new key/value pairs---
        i.putExtra("str1", "This is a string");
        i.putExtra("age1", 25);
        //---use a Bundle object to add new key/values
        // pairs---
        Bundle extras = new Bundle();
        extras.putString("str2", "This is another string");
        extras.putInt("age2", 35);
        //---attach the Bundle object to the Intent object---
        i.putExtras(extras);
        //---start the activity to get a result back---
        startActivityForResult(i, 1);
    public void onActivityResult(int requestCode,
    int resultCode, Intent data)
        //---check if the request code is 1---
        if (requestCode == 1) {
            //---if the result is OK---
            if (resultCode == RESULT_OK) {
                //---get the result using getIntExtra()---
                    data.getIntExtra("age3", 0)),
                //---get the result using getData()---
                Toast.makeText(this, data.getData().toString(),
    @Override
           Intent i = new
           // pairs---
    7.按F11调试。
效果图:
    程序第一次启动:
    跳转到SecondActivity:
    返回PassDataActivity:
作者 manoel的专栏
