阅读:2906回复:0
Android 程式开发:(三)碎片简介 —— 3.1 动态添加
更多 发布于:2012-09-06 14:04
fragment的真正用处是在程序运行过程中动态地添加。
1.工程目录。
2.res/layout/main.xml
    Android:orientation="horizontal" >
</LinearLayout>
3.res/layout/fragment1.xml
    Android:background="#00FF00"
    <TextView
        Android:id="@+id/lblFragment1"
        Android:text="This is fragment #1"
        Android:textColor="#000000"
        Android:textSize="25sp" />
</LinearLayout>
4.res/layout/fragment2.xml
    Android:background="#FFFE00"
    <TextView
        Android:text="This is fragment #2"
</LinearLayout>
5.Fragment1.java
package net.horsttnann.Fragments;
import net.horsttnann.Fragments.R;
import Android.app.Fragment;
import Android.os.Bundle;
import Android.view.LayoutInflater;
import Android.view.View;
import Android.view.ViewGroup;
public class Fragment1 extends Fragment {
    @Override
    public View onCreateView(LayoutInflater inflater, ViewGroup container,
            Bundle savedInstanceState) {
        // ---Inflate the layout for this fragment---
        return inflater.inflate(R.layout.fragment1, container, false);
6.Fragment2.java
public class Fragment2 extends Fragment {
    @Override
        return inflater.inflate(R.layout.fragment2, container, false);
7.FragmentsActivity.java
import Android.app.Activity;
import Android.app.FragmentManager;
import Android.app.FragmentTransaction;
import Android.view.Display;
import Android.view.WindowManager;
public class FragmentsActivity extends Activity {
    @Override  www.atcpu.com
        FragmentManager fragmentManager = getFragmentManager();
        FragmentTransaction fragmentTransaction = fragmentManager
                .beginTransaction();
        // ---get the current display info---
        WindowManager wm = getWindowManager();
        Display d = wm.getDefaultDisplay();
        if (d.getWidth() > d.getHeight()) {
            // ---landscape mode---
            Fragment1 fragment1 = new Fragment1();
            // Android.R.id.content refers to the content
            // view of the activity
            fragmentTransaction.replace(Android.R.id.content, fragment1);
        } else {
            // ---portrait mode---
            Fragment2 fragment2 = new Fragment2();
            fragmentTransaction.replace(Android.R.id.content, fragment2);
        // ---add to the back stack---
        fragmentTransaction.addToBackStack(null);
        fragmentTransaction.commit();
8.调试。
效果图:
摘自 manoel的专栏
