阅读:3216回复:0
在源码中监听activity启动
更多 发布于:2012-09-06 14:05
上周做一个小的功能,修改statusbar,在launcher界面和其它应用界面显示不同的背景色和icon,最初想的就是接受系统activity启动的广播,进行判断,研究了一段时间,发现接受不到广播,最后在网上搜索资料,发现monkey代码中有一段代码可以接受activity启动和resume事件。最终满足要求。代码如下
  1.设置观察者
  mAm = ActivityManagerNative.getDefault();
        try {
            mAm.setActivityController(new ActivityController());
       } catch (RemoteException e) {
            System.err.println("** Failed talking with activity manager!");
2.观察者类
private class ActivityController extends IActivityController.Stub {
//start
        public boolean activityStarting(Intent intent, String pkg) {
            currentPkg = pkg;
        mHandler.sendEmptyMessage(MSG_UPDATE_BACKGROUND);
            //currentIntent = intent;
            return true;
//resume
        public boolean activityResuming(String pkg) {
           currentPkg = pkg;
            return true;
  public int appEarlyNotResponding(String processName, int pid, String annotation){
return 0;
        public boolean appCrashed(String processName, int pid,
                String shortMsg, String longMsg,
                long timeMillis, String stackTrace) {
           /* System.err.println("// CRASH: " + processName + " (pid " + pid + ")");
            System.err.println("// Short Msg: " + shortMsg);
            System.err.println("// Long Msg: " + longMsg);
            System.err.println("// Build Label: " + Build.FINGERPRINT);
            System.err.println("// Build Changelist: " + Build.VERSION.INCREMENTAL);
            System.err.println("// Build Time: " + Build.TIME);
            System.err.println("// " + stackTrace.replace("\n", "\n// "));
            if (!mIgnoreCrashes) {
                synchronized (Monkey.this) {
                    mAbort = true;
                return !mKillProcessAfterError;
            return false;
        public int appNotResponding(String processName, int pid, String processStats) {
           // System.err.println("// NOT RESPONDING: " + processName + " (pid " + pid + ")");
            //System.err.println(processStats);
         return 0;
在一个service中加入以上代码,当activity活动时就会调用上述的方法packagename为activity的所在包名
由于ActivityManagerNative和IActivityController都属于内部类,所以该方法需要在源码环境下才可以使用
附一份IActivityController.aidl源码函数说明
package Android.app;
import Android.content.Intent;
* Testing interface to monitor what is happening in the activity manager
* while tests are running.  Not for normal application development.
* {@hide}
interface IActivityController
     * The system is trying to start an activity.  Return true to allow
     * it to be started as normal, or false to cancel/reject this activity.
    boolean activityStarting(in Intent intent, String pkg);
     * The system is trying to return to an activity.  Return true to allow
     * it to be resumed as normal, or false to cancel/reject this activity.
     */  www.atcpu.com
    boolean activityResuming(String pkg);
     * An application process has crashed (in java).  Return true for the
     * normal error recovery (app crash dialog) to occur, false to kill
     * it immediately.
            long timeMillis, String stackTrace);
     * Early call as soon as an ANR is detected.
    int appEarlyNotResponding(String processName, int pid, String annotation);
     * An application process is not responding.  Return 0 to show the "app
     * not responding" dialog, 1 to continue waiting, or -1 to kill it
     * immediately.
    int appNotResponding(String processName, int pid, String processStats);
作者:Androidchuxueze
