阅读:3907回复:0
联系人头像android
更多 发布于:2012-09-06 14:06
<pre class="java" name="code">ContentResolver cr = getContentResolver();
Cursor cursor = cr.query(ContactsContract.Contacts.CONTENT_URI, null, "DISPLAY_NAME = '" + "gm" + "'", null,
                null);
if (cursor.moveToFirst()) {
//获得联系人的id
String contactId = cursor.getString(cursor.getColumnIndex(ContactsContract.Contacts._ID));
//修改联系人的头像
Bitmap sourceBitmap = BitmapFactory.decodeResource(getResources(), R.drawable.img2);
final ByteArrayOutputStream os = new ByteArrayOutputStream();
// 将Bitmap压缩成PNG编码,质量为100%存储
sourceBitmap.compress(Bitmap.CompressFormat.PNG, 100, os);
byte[] avatar =os.toByteArray();
ContentValues values = new ContentValues();
values.put(Data.RAW_CONTACT_ID, contactId);
values.put(Data.MIMETYPE, Photo.CONTENT_ITEM_TYPE);
values.put(Photo.PHOTO, avatar);
getContentResolver().update(Data.CONTENT_URI, values, null, null);</pre>
构建uri
Uri contactUri = ContentUris.withAppendedId(ContactsContract.Data.CONTENT_URI,
Long.parseLong(contactId));
//带路径
Uri photoUri = Uri.withAppendedPath(contactUri, ContactsContract.Contacts.Photo.DATA15);
此uri为content://com.Android.contacts/contactId/data15
获得联系人图片
// 获得联系人图片,     读取的是Data类中的data15字段
Uri uri = ContentUris.withAppendedId(ContactsContract.Contacts.CONTENT_URI,
Long.parseLong(contactId)); InputStream input =
ContactsContract.Contacts.openContactPhotoInputStream(cr, uri);
Bitmap contactPhoto = BitmapFactory.decodeStream(input);
ImageView img=(ImageView)findViewById(R.id.img);
img.setImageBitmap(contactPhoto);
查询电话记录
// 查询所有
// Cursor cursor=resolver.query(CallLog.Calls.CONTENT_URI, null,
        // null,null, null);
// 查询指定号码
          "number=? and type=?", new String[]{"15555215556","2"}, null);
while(cursor.moveToNext()){ //取得联系人名字 PhoneLookup.DISPLAY_NAME int nameFieldColumnIndex
         =cursor.getColumnIndex(CallLog.Calls.CACHED_NAME); String
    contact=cursor.getString(nameFieldColumnIndex);
//取得电话号码
int numberFieldColumnIndex=cursor.getColumnIndex(PhoneLookup.NUMBER);
String number=cursor.getString(numberFieldColumnIndex);
作者:hahashui123
