软件开发
Android开发
level—list设置背景用法
level—list设置背景用法
发布于:2012-09-06 14:06
学习
Android
中statusbar源码,发现电量图标中使用了<level—list>标签的stat-sys-battery.xml.
<level-list xmlns:
Android
="www.at
cpu
.com">
<item
Android
:maxLevel="2"
Android
:drawable="@
Android
:drawable/stat_sys_battery_0" />
<item
Android
:maxLevel="7"
Android
:drawable="@
Android
:drawable/stat_sys_battery_5" />
<item
Android
:maxLevel="12"
Android
:drawable="@
Android
:drawable/stat_sys_battery_10" />
<item
Android
:maxLevel="17"
Android
:drawable="@
Android
:drawable/stat_sys_battery_15" />
<item
Android
:maxLevel="22"
Android
:drawable="@
Android
:drawable/stat_sys_battery_20" />
<item
Android
:maxLevel="27"
Android
:drawable="@
Android
:drawable/stat_sys_battery_25" />
<item
Android
:maxLevel="32"
Android
:drawable="@
Android
:drawable/stat_sys_battery_30" />
<item
Android
:maxLevel="37"
Android
:drawable="@
Android
:drawable/stat_sys_battery_35" />
<item
Android
:maxLevel="42"
Android
:drawable="@
Android
:drawable/stat_sys_battery_40" />
<item
Android
:maxLevel="47"
Android
:drawable="@
Android
:drawable/stat_sys_battery_45" />
<item
Android
:maxLevel="52"
Android
:drawable="@
Android
:drawable/stat_sys_battery_50" />
<item
Android
:maxLevel="57"
Android
:drawable="@
Android
:drawable/stat_sys_battery_55" />
<item
Android
:maxLevel="62"
Android
:drawable="@
Android
:drawable/stat_sys_battery_60" />
<item
Android
:maxLevel="67"
Android
:drawable="@
Android
:drawable/stat_sys_battery_65" />
<item
Android
:maxLevel="72"
Android
:drawable="@
Android
:drawable/stat_sys_battery_70" />
<item
Android
:maxLevel="77"
Android
:drawable="@
Android
:drawable/stat_sys_battery_75" />
<item
Android
:maxLevel="82"
Android
:drawable="@
Android
:drawable/stat_sys_battery_80" />
<item
Android
:maxLevel="87"
Android
:drawable="@
Android
:drawable/stat_sys_battery_85" />
<item
Android
:maxLevel="92"
Android
:drawable="@
Android
:drawable/stat_sys_battery_90" />
<item
Android
:maxLevel="97"
Android
:drawable="@
Android
:drawable/stat_sys_battery_95" />
<item
Android
:maxLevel="100"
Android
:drawable="@
Android
:drawable/stat_sys_battery_100" />
</level-list>
代码中使用
v.setImageResource(R.drawable.stat-sys-battery);
v.setImageLevel(levle);
即可通过不同的电量设置不同的图标,节省了大量的判断代码
