阅读:4463回复:0
vb读取几种导航仪表的方法集合
更多 发布于:2012-09-08 11:54
[vb]
仪表主要有日本GP30,GP31,GP91,SAMYANG,另外还有国产的仪表,以供大家参考,这是本人为航务公司开发读取导航仪表的数据,数据主要有航速、经度、纬度和其它数据,但是其公司使用的导航仪有4种,每一种都写一个读数方法,所以是很郁闷的,好在最后都写出来了。
[vb]
Dim tmpStr As String
    Dim i As Integer
    Dim j As Integer
    Dim k As Integer
    Dim l As Integer
    Dim RetValue
    On Error Resume Next
    Dim TmpA As String
    Dim TmpB As String
    Dim TmpC As String
    Dim TmpD As String
    Dim TmpE As String
    RetValue = MSCGps.Input
    j = LenB(RetValue)
    For i = 0 To j - 1
        If RetValue(i) = ;H24 And RetValue(i + 1) = ;HA0 And j > 31 Then
           For k = 0 To 3
              TmpA = TmpA ; Replace(Format(Hex(RetValue(i + 6 + k)), "@@"), " ", "0")
           Next
           LblInfo(0).Caption = Val(TmpA) / 1000 '经度
           For k = 0 To 3
              TmpB = TmpB ; Replace(Format(Hex(RetValue(i + 10 + k)), "@@"), " ", "0")
           Next
           LblInfo(1).Caption = Val(TmpB) / 1000 '纬度
           For k = 0 To 1
              TmpC = TmpC ; Replace(Format(Hex(RetValue(i + 14 + k)), "@@"), " ", "0")
           Next
           LblInfo(2).Caption = Val(TmpC)        '速度
           For k = 0 To 1
              TmpD = TmpD ; Replace(Format(Hex(RetValue(i + 16 + k)), "@@"), " ", "0")
           Next
           Label2(7).Caption = TmpD              '方位
          TmpE = TmpE ; Replace(Format(Hex(RetValue(i + 18)), "@@"), " ", "0")
          Label2(6).Caption = TmpE               '状态
        End If
    Next
'    tmpStr = MSCGps.Input
'    StrBuf = tmpStr
    '$GPRMC,055214,A,3158.0956,N,12024.4596,E,0.0,326,200511,5,W*68\CR\LF
'    If UCase(Mode) = "GP31" Then
'        i = InStr(1, tmpStr, "$GPRMC", vbTextCompare)
'        If i Then
'             LblInfo(0).Caption = Val(Mid(tmpStr, i + 16, 2)) ; " " ; Val(Mid(tmpStr, i + 18, 7))                      '经度
'             LblInfo(1).Caption = Mid(tmpStr, i + 28, 3) ; " " ; Mid(tmpStr, i + 31, 7)                                '纬度
'             LblInfo(2).Caption = Val(Mid(tmpStr, i + 41, 4))                                                          '速度
'             LblInfo(3).Caption = Mid(tmpStr, i + 7, 2) ; ":" ; Mid(tmpStr, i + 9, 2) ; ":" ; Mid(tmpStr, i + 11, 2)   '时间
'        End If
'        '$GPVTG,,T,302,M,0.0,N,0.0,K\CR\LF
'        j = InStr(1, tmpStr, "$GPVTG", vbTextCompare)
'        If j Then
'             Label2(7).Caption = Val(Mid(tmpStr, j + 10, 5))                                                           '方位
'             Label2(6).Caption = Val(Mid(tmpStr, j + 24, 4))                                                           '状态
'        End If
'        '$GPZDA,055217,20,05,2011,-8,0\CR\LF
'        k = InStr(1, tmpStr, "$GPZDA", vbTextCompare)
'        If k Then
'             Label2(4).Caption = Mid(tmpStr, k + 20, 4) ; "-" ; Mid(tmpStr, k + 17, 2) ; "-" ; Mid(tmpStr, k + 14, 2)  '日期
'        End If
'   End If
'     If UCase(Mode) = "SAMYANG" Then
'        If i Then
'            LblInfo(0).Caption = Val(Mid(tmpStr, i + 19, 9))  '经度
'            LblInfo(1).Caption = Mid(tmpStr, i + 31, 10)      '纬度
'            LblInfo(2).Caption = Val(Mid(tmpStr, i + 44, 4))  '速度
'        End If
'        If j Then
'             Label2(7).Caption = Mid(tmpStr, j + 17, 4) ' Val(Mid(tmpStr, j + 12, 4))
'             Label2(6).Caption = Mid(tmpStr, j + 24, 4)
'        End If
'        If k Then
'        End If
'   End If
'    '$GPVTG,,T,153.6,M,11.9,N,22.0,K,A*05
'    '$GPVTG,,T,147.8,M,11.8,N,21.9,K,A*05
'    '$GPVTG,,T,124.9,M,11.4,N,21.1,K,A*05
'    '$GPVTG,,T,168.7,M,8.0,N,14.8,K,A*30
'    '$GPVTG,,T,166.7,M,9.4,N,17.4,K,A*34
'    '$GPVTG,,T,88.0,M,9.4,N,17.4,K,A*02
'    '$GPVTG,,T,251.7,M,0.1,N,0.2,K,A*0F
'    '$GPVTG,,T,173.8,M,1.3,N,2.4,K,A*04
'   If UCase(Mode) = "GP90" Then
'        Shape1.FillColor = vbGreen
'        i = InStr(1, tmpStr, "$GPGLL", vbTextCompare)
'        If i Then
'            LblInfo(1).Caption = Mid(tmpStr, i + 7, 8)
'            LblInfo(3).Caption = Mid(tmpStr, i + 32, 6)
'        End If
'        If j Then
'            Dim TmpV As String
'            TmpV = Mid(tmpStr, j + 6, 28)
'         '   Debug.Print TmpV
'            Dim m As Integer
'            Dim n As Integer
'           ' Dim k As Integer
'            m = InStr(1, TmpV, "N")
'            n = InStr(1, TmpV, "K")
'            k = n - m - 3
'           ' Debug.Print Mid(TmpV, m + 2, k)
'            LblInfo(2).Caption = Val(Mid(TmpV, m + 2, k))         '速度
'             'LblInfo(2).Caption = Val(Mid(tmpStr, j + 24, 4))    '速度
'            m = InStr(1, TmpV, "T")
'            n = InStr(1, TmpV, "M")
'            k = n - m - 3
'            Label2(7).Caption = Val(Mid(TmpV, m + 2, k))          '方位
'           ' Label2(7).Caption = Val(Mid(tmpStr, j + 10, 5))
'           '  SaveInfo tmpStr
'        End If
'        If k Then
'             Label2(4).Caption = Mid(tmpStr, k + 23, 4) ; "-" ; Mid(tmpStr, k + 20, 2) ; "-" ; Mid(tmpStr, k + 17, 2)
'        End If
'        l = InStr(1, tmpStr, "$GPRMB", vbTextCompare)
'        Label2(6).Caption = Val(Mid(tmpStr, l + 56, 3))
'   End If
