阅读:2823回复:0
delphi Zlib 流压缩解压
更多 发布于:2012-09-08 13:03
procedure UnCompressionStream(var ASrcStream:TMemoryStream); //解压缩
var
nTmpStream:TDecompressionStream;
nDestStream:TMemoryStream;
nBuf: array[1..512] of Byte;
nSrcCount: integer;
begin
ASrcStream.Position := 0;
nDestStream := TMemoryStream.Create;
nTmpStream := TDecompressionStream.Create(ASrcStream);
try
    repeat
      //读入实际大小
      nSrcCount := nTmpStream.Read(nBuf, SizeOf(nBuf));
      if nSrcCount > 0 then
        nDestStream.Write(nBuf, nSrcCount);
    until (nSrcCount = 0);
    ASrcStream.Clear;
    ASrcStream.LoadFromStream(nDestStream);
finally
    nDestStream.Clear;
    nDestStream.Free;
    nTmpStream.Free;
end;
end;
procedure CompressionStream(var ASrcStream:TMemoryStream;ACompressionLevel:Integer = 2); //压缩流
var
nTmpStream:TCompressionStream;
nCompressionLevel:TCompressionLevel;
begin
try
    //级别
    case ACompressionLevel of
      0:nCompressionLevel := clNone;
      1:nCompressionLevel := clFastest;
      2:nCompressionLevel := clDefault;
      3:nCompressionLevel := clMax;
      else
    end;
    //开始压缩
    nTmpStream := TCompressionStream.Create(nCompressionLevel,nDestStream);
    try
      ASrcStream.SaveToStream(nTmpStream);
    finally
      nTmpStream.Free;//释放后nDestStream才会有数据
    end;
    ASrcStream.Clear;
finally
    nDestStream.Clear;
    nDestStream.Free;
end;
end;
