阅读:3588回复:0
Delphi openGL 编程入门
更多 发布于:2012-09-08 13:04
openGL 3D编程方面C语言的较多,delphi openGL网上资料比较少。
看到warrially兄弟研究的很虎,很喜欢delphi 游戏编程,也学学.
网上最原始的就是老外的一篇《delphi下的OpenGL开发入门》被翻译过来:
http://www.atcpu.com/kf/201012/79716.html
一般都在Draw里面,也可以其他单元独立出来。
procedure TForm1.Draw;
begin
// GL画图开头
         glBegin( GL_POINTS);
            glEnd();
// GL画图结尾
  SwapBuffers(wglGetCurrentDC);
end;
基本的图形无非 点线多边形球曲面。
glBegin()命令常用枚举常量
函数为:
procedure glBegin(mode: GLenum);stdcall;
procedure glEnd;stdcall;
枚举常量意义值
GL_POINTS绘制点$0000
GL_LINES绘制线段$0001
GL_LINE_STRIP绘制折线$0002
GL_LINE_LOOP绘制闭合折线$0003
GL_TRIANGLES绘制三角形$0004
GL_TRIANGLE_STRIP绘制连续三角形$0005
GL_TRAINGLE_FAN绘制三角扇形$0006
GL_QUADS绘制四边形$0007
GL_QUAD_STRIP绘制连续四边形$0008
GL_POLYGON绘制多边形$0009
//=============借用这个最实用的最基础的代码
unit openGLdemo;
interface
uses
OpenGL, Windows, Messages, SysUtils, Classes, Graphics, Controls, Forms, Dialogs,
StdCtrls, ExtCtrls, ComCtrls;
type
  TForm1 = class(TForm)
    pnl1: TPanel;
    tmr1: TTimer;
  procedure FormCreate(Sender: TObject);
    procedure tmr1Timer(Sender: TObject);
  private
  procedure Draw; //Draws an OpenGL scene on request
  public
end;
var
Form1: TForm1;
implementation
{$R *.DFM}
procedure setupPixelFormat(DC:HDC);
  const
  pfd:TPIXELFORMATDESCRIPTOR =
  (nSizeizeof(TPIXELFORMATDESCRIPTOR); // size
  nVersion:1; // version
  dwFlags:PFD_SUPPORT_OPENGL or PFD_DRAW_TO_WINDOW or PFD_DOUBLEBUFFER; // support double-buffering
  iPixelType:PFD_TYPE_RGBA; // color type
  cColorBits:24; // preferred color depth
  cRedBits:0; cRedShift:0; // color bits (ignored)
  cGreenBits:0; cGreenShift:0;
  cBlueBits:0; cBlueShift:0;
  cAlphaBits:0; cAlphaShift:0; // no alpha buffer
  cAccumBits: 0;
  cAccumRedBits: 0; // no accumulation buffer,
  cAccumGreenBits: 0
