阅读:3370回复:0
Delphi 学习日记:禁止TEdit或TMemo的“Ctrl+V”粘贴
更多 发布于:2012-09-08 13:04
今天去About.com逛了逛,学到一点东西,记下来
No "Paste" for you!
To intercept any key combination for a TEdit (or TMemo or more generally TCustomEdit) you need to handle the OnKeyDown event.
Put a TEdit named "Edit1" on a form (named "Form1"). Handle Edit1's OnKeyDown event as:
uses Clipbrd, ...
//disable CTRL + V ("Paste") :: handles Edit1.OnKeyDown
procedure TForm1.Edit1KeyDown(Sender: TObject; var Key: word; Shift: TShiftState) ;
begin
   if ((ssCtrl in Shift) AND (Key = ord('V'))) then
   begin
     if Clipboard.HasFormat(CF_TEXT) then ClipBoard.Clear;
     Edit1.SelText := '"Paste" DISABLED!';
     Key := 0;
   end;
end;
When the user presses the CTRL+V key combination while Edit1 has the input focus ... the code above will clear the clipboard and "paste" the '"Paste" DISABLED!' text into the edit control.
