阅读:4240回复:0
Delphi中始终用WebBrowser打开网页
更多 发布于:2012-09-08 13:05
要在同一个webBrowser里显示,可以这样:
    再放一个小的WebBrowser2,设置它在WebBrowser1下面(设置Visible为False好象无效),
    // 在WebBrowser1的OnNewWindow2事件中:
    procedure TForm1.WebBrowser1NewWindow2(Sender: TObject;
    var ppDisp: IDispatch; var Cancel: wordBool);
    begin
    ppDisp := WebBrowser2.Application; // 新的窗口先指向WebBrowser2
    end;
    // 在WebBrowser2的OnBeforeNavigate2事件中:
    procedure TForm1.WebBrowser2BeforeNavigate2(Sender: TObject;
    const pDisp: IDispatch; var URL, Flags, TargetFrameName, PostData,
    Headers: OleVariant; var Cancel: wordBool);
    begin
    WebBrowser1.Navigate(string(URL)); // 再指回WebBrowser1
    Cancel := True;
    end;
    可以这样,窗体中放置两个PANEL,其中PANEL1中放WebBrowser1,PANEL2中放WebBrowser2,PANEL1和PANEL2、WebBrowser1和WebBrowser2的LEFT,TOP等所有属性设为一样。PANEL2的VISIBLE设为FALSE。然后添加代码如下即可:
    begin
    ppDisp:=WebBrowser2.Application;
    panel1.Visible:=false;
    panel2.Visible:=true;
    end;
    procedure TForm1.WebBrowser2NewWindow2(Sender: TObject;
    begin
    ppDisp:=WebBrowser1.Application;
    panel2.Visible:=false;
    panel1.Visible:=true
    我只回答第一个问题,看你给多少分:
    1 NewWindow2的在接口中定义的原形:
    procedure NewWindow2(Sender: TObject; var ppDisp: IDispatch;
    2 通过传递一个WebBrowser的控制借口给ppDisp可以让新网页在指定的Wb中浏览
    ppDisp:=WebBrowser1.Browser.Controlinterface;
    3 在刚才传递的WebBrowser的OnBeforeNavigate2事件中就可以获得将要打开的
    URL了!
    function SaveToStream(AStream: TStream): HRESULT;
    var
    IpStream: IPersistStreamInit;
    begin
    with browser1 do
    begin
    while ReadyState <> READYSTATE_COMPLETE do
    Forms.Application.ProcessMessages;
    if Assigned(Document) then
    begin
    IpStream := Document as IPersistStreamInit;
    Result := IpStream.save(TStreamAdapter.Create(AStream), TRUE);
    end else Result := S_FALSE;
    end;
    end;
    function Loadfromstream(AStream:TStream):hresult;
    begin
    with browser1 do
    begin
    if not Assigned(Document) then
    begin
    navigate2(about:blank,0,0,0,0);
    while readystate <> READYSTATE_COMPLETE do Forms.Application.ProcessMessages;
    end;
    AStream.seek(0, 0);
    Result := (Document as IPersistStreamInit).Load(TStreamadapter.Create(AStream));
    end;
    end;
