阅读:7865回复:0
查询条件的封装(二)
更多 发布于:2012-09-08 13:06
TConditionItem
1 { TConditionItem }
2
3 procedure TConditionItem.Assign(Source: TPersistent);
4 begin
5   if Source is TConditionItem then
6   begin
7     if Assigned(Collection) then Collection.BeginUpdate;
8     try
9       //RestoreDefaults;
10       ConditionName := TConditionItem(Source).ConditionName;
11       ConditionLabel := TConditionItem(Source).ConditionLabel;
12       ConditionEditType := TConditionItem(Source).ConditionEditType;
13       ConditionValueType := TConditionItem(Source).ConditionValueType;
14     finally
15       if Assigned(Collection) then Collection.EndUpdate;
16     end;
17   end
18   else
19     inherited Assign(Source);
20 end;
21
22 constructor TConditionItem.Create(Collection: TCollection);
23 begin
24   try
25     inherited Create(Collection);
26     FConditionName := Self.ClassName+IntToStr(Collection.Count);
27     FConditionLabel := '查询条件'+IntToStr(Collection.Count);
28     FConditionValueType := cidtString;
29     FConditionEditType := cetButtonEdit;
30     if Collection is TConditionItems then
31     begin
32       if TConditionItems(Collection).FConditionUI <> nil then
33         TConditionItems(Collection).FConditionUI.BuildConditionGridByItems;
34     end;
35   finally
36
37   end;
38 end;
39
40 procedure TConditionItem.SetConditionEditType(
41   const Value: TConditionEditType);
42 begin
43   FConditionEditType := Value;
44 end;
45
46 procedure TConditionItem.SetConditionLabel(const Value: string);
47 begin
48   FConditionLabel := Value;
49 end;
50
51 procedure TConditionItem.SetConditionName(const Value: string);
52 begin
53   FConditionName := Value;
54 end;
55
56 procedure TConditionItem.SetConditionValue(const Value: Variant);
57 begin
58   FConditionValue := Value;
59 end;
60
61 procedure TConditionItem.SetConditionValueType(
62   const Value: TConditionItemDataType);
63 begin
64   FConditionValueType := Value;
65 end;
66
67 procedure TConditionItem.SetIndex(Value: Integer);
68 begin
69   inherited SetIndex(Value);
70 // 这里不需要处理,SetIndex会触发Changed,从而触发容器的Update。Update已经有控制表格的处理逻辑。
71 //  if Collection is TConditionItems then
72 //  begin
73 //    if TConditionItems(Collection).FConditionUI <> nil then
74 //      TConditionItems(Collection).FConditionUI.BuildConditionGridByItems;
75 //  end;
76 end;
  TConditionItems
1 { TConditionItems }
2
3 function TConditionItems.Add: TConditionItem;
4 begin
5   Result := TConditionItem(inherited Add);
6 end;
7
8 constructor TConditionItems.Create(AConditionUI: TConditionUI;
9   ItemClass: TItemClass);
10 begin
11   inherited Create(ItemClass);
12   FConditionUI := AConditionUI;
13 end;
14
15 function TConditionItems.FindItemIndex(index: Integer): TConditionItem;
16 var
17   i : Integer;
18 begin
19   Result := nil;
20   for i := 0 to Count - 1 do
21   begin
22     if Items.Index = index then
23     begin
24       Result := Items;
25       Break;
26     end;
27   end;
28 end;
29
30 function TConditionItems.FindItemName(
31   AConditionName: string): TConditionItem;
32 var
33   i : Integer;
34 begin
35   Result := nil;
36   for i := 0 to Count - 1 do
37   begin
38     if Items.ConditionName = AConditionName then
39     begin
40       Result := Items;
41       Break;
42     end;
43   end;
44 end;
45
46 function TConditionItems.GetItems(Index: Integer): TConditionItem;
47 begin
48   Result := TConditionItem(inherited Items[Index]);
49 end;
50
51 function TConditionItems.GetOwner: TPersistent;
52 begin
53   Result := FConditionUI;
54 end;
55
56 procedure TConditionItems.SetItems(Index: Integer;
57   const Value: TConditionItem);
58 begin
59   Items[Index].Assign(Value);
60 end;
61
62 procedure TConditionItems.Update(Item: TCollectionItem);
63 begin
64   if (FConditionUI.ConditionGrid = nil) or (csLoading in FConditionUI.ConditionGrid.ComponentState) then Exit;
65   if Item = nil then
66   begin
67
68   end
69   else
70   begin
71
72   end;
73   FConditionUI.BuildConditionGridByItems;
74 end;
  TConditionUI
  1 { TConditionUI }
  2
  3 procedure TConditionUI.BuildConditionGridByItems;
  4 const AColumnCaption: array[0..2] of string = ('查询条件', '条件值', '隐藏列');
  5 var
  6   i : integer;
  7   Column : TcxGridColumn;
  8 begin
  9   if FConditionGrid <> nil then
10   begin
11     with FConditionGrid do
12     begin
13       BeginUpdate;
14       // 清空表格记录
15       OptionsSelection.CellMultiSelect := true;
16       DataController.ClearSelection;
17       DataController.SelectAll;
18       DataController.DeleteSelection;
19       OptionsSelection.CellMultiSelect := False;
20
21       // 清空表格列
22       for i := FConditionGrid.ColumnCount - 1 downto 0 do
23       begin
24         FConditionGrid.Columns.Free;
25       end;
26
27       // 创建表格列
28       for i := 0 to 2 do
29       begin
30         Column := FConditionGrid.CreateColumn;
31         Column.Caption := AColumnCaption;
32         if i = 0 then
33           Column.Options.Focusing := False
34         else
35         if i = 2 then
36           Column.Visible := False;
37       end;
38       // 创建表格行 www.atcpu.com
39       for i := 0 to FConditionItems.Count -1 do
40       begin
41         DataController.AppendRecord;
42         DataController.Values[i, 0] := TConditionItem(FConditionItems.FindItemIndex(i)).ConditionLabel; //TConditionItem(FConditionItems.FindItemID(i)).ConditionLabel; //FConditionItems.Items.ConditionLabel;
43         DataController.Values[i, 2] := 0;
44         DataController.Values[i, 1] := '2012-01-01';
45       end;
46
47       EndUpdate;
48     end;
49   end;
50 end;
51
52 constructor TConditionUI.Create(AOwner: TComponent);
53 begin
54   inherited Create(AOwner);
55   FSelectedStyle := TcxStyle.Create(Self);
56   FSelectedStyle.Name := 'cxSelectedStyle';
57   FSelectedStyle.Font.Name := 'MS Sans Serif';
58   FSelectedStyle.Font.Size := 8;
59   FSelectedStyle.Color := $00FED2B3;
60   FSelectedStyle.AssignedValues := [svColor, svTextColor];
61
62   FNormalStyle := TcxStyle.Create(Self);
63   FNormalStyle.Name := 'cxNormalStyle';
64   FNormalStyle.Font.Name := '宋体';
65   FNormalStyle.Font.Size := 9;
66   FNormalStyle.Color := $00FED2B3;
67   FNormalStyle.AssignedValues := [svColor, svFont, svTextColor];
68
69   FConditionItems := CreateConditionItems;
70 end;
71
72 function TConditionUI.CreateConditionItems: TConditionItems;
73 begin
74   Result := TConditionItems.Create(Self, TConditionItem);
75 end;
76
77 procedure TConditionUI.CustomDrawIndicatorCell(Sender: TcxGridTableView;
78   ACanvas: TcxCanvas; AViewInfo: TcxCustomGridIndicatorItemViewInfo;
79   var ADone: Boolean);
80 var
81   vstr: string;
82   vCol: integer;
83   vIndicatorViewInfo: TcxGridIndicatorRowItemViewInfo;
84   vTextRect: TRect;
85   vStyle: TcxStyle;
86 begin
87 // 行号设置
88   if not (AViewInfo is TcxGridIndicatorRowItemViewInfo) then
89     Exit;
90
91   vTextRect := AViewInfo.ContentBounds;
92   vIndicatorViewInfo := AViewInfo as TcxGridIndicatorRowItemViewInfo;
93   InflateRect(vTextRect, -2, -1);
94   //vCol := 0;
95
96   //判断有没有子集
97   if Sender.FindItemByName('gd_ClassViews_SonCount') <> nil then
98   begin
99     vCol := Sender.FindItemByName('gd_ClassViews_SonCount').Index;
101     if vIndicatorViewInfo.GridRecord.Values[vCol] > 0 then
102       vstr := IntToStr(vIndicatorViewInfo.GridRecord.Index + 1) + '..'
103     else
104       vstr := IntToStr(vIndicatorViewInfo.GridRecord.Index + 1);
105   end
106   else
107     vstr := IntToStr(vIndicatorViewInfo.GridRecord.Index + 1);
108
109   if vIndicatorViewInfo.GridRecord.Selected then
110     vStyle := FSelectedStyle
111   else
112     vStyle := FNormalStyle;
113   Sender.LookAndFeelPainter.DrawHeader(ACanvas, AViewInfo.ContentBounds,
114     vTextRect, [], cxBordersAll, cxbsNormal, taCenter, vaCenter,
115     False, False, vstr,
116     vStyle.Font, vStyle.TextColor, vStyle.Color);
117
118   ADone := True;
119 end;
120
121 destructor TConditionUI.Destroy;
122 begin
123   FConditionItems.Free;
124   FConditionItems := nil;
125
126   inherited;
127 end;
128
129 function TConditionUI.GetConditionValue(AConditionName: string): Variant;
130 var
131   AConditionItem : TConditionItem;
132 begin
133   Result := EmptyParam;
134   AConditionItem := FConditionItems.FindItemName(AConditionName);
135   if AConditionItem <> nil then
136   begin
137     Result := AConditionItem.ConditionValue;
138   end;
139 end;
140
141 procedure TConditionUI.SetConditionGrid(const Value: TcxGridTableView);
142 begin
143   FConditionGrid := Value;
144   if FConditionGrid <> nil then
145   begin
146     // 行号
147     FConditionGrid.OptionsView.Indicator := True;
148     FConditionGrid.OptionsView.IndicatorWidth := 24;
149     FConditionGrid.OnCustomDrawIndicatorCell := CustomDrawIndicatorCell;
150     FConditionGrid.OptionsView.GroupByBox := False;
151   end;
152 end;
153
154 procedure TConditionUI.SetConditionItems(const Value: TConditionItems);
155 begin
156   FConditionItems.Assign(Value);
157 end;
158
159 procedure TConditionUI.SetNormalStyle(const Value: TcxStyle);
160 begin
161   FNormalStyle.Assign(Value);
162 end;
163
164 procedure TConditionUI.SetSelectedStyle(const Value: TcxStyle);
165 begin
166   FSelectedStyle.Assign(Value);
167 end;
以上代码后续应该有变更。因为现在只是一个雏形,也是记录自己学习和完成的一个过程。
