阅读:9460回复:0
TFileStream用法
更多 发布于:2012-09-08 13:06
// 写入中文
procedure TForm1.btn1Click(Sender: TObject);
var
   Stream : TFileStream;
  fn : string;
  fname : string;
  Buffer : TBytes;
  Encoding : TEncoding;
begin
  fn := ExtractFilePath(Application.ExeName) + 'config.dat';
  try
    Stream := TFileStream.Create(fn, fmCreate);
    Stream.Position := 0;
    fname := '这是一个测试';
    Encoding := TEncoding.Unicode;
    Buffer := Encoding.GetBytes(fname);
    Size := Length(Buffer);
    Stream.WriteBuffer(Pointer(Buffer)^, Size);
  finally
  Stream.Free;
  end;
end;
// 读取中文
procedure TForm1.btn2Click(Sender: TObject);
var
  fn : string;
  fname : string;
  Buffer : TBytes;
begin
  try
    Stream := TFileStream.Create(fn, fmOpenRead);
    // fname := '这是一个测试';
    // Encoding := TEncoding.Unicode;
    // Buffer := Encoding.GetBytes(fname);
    // Size := Length(Buffer);
    SetLength(Buffer, Size);
    Stream.ReadBuffer(Pointer(Buffer)^, Size);
    Size := TEncoding.GetBufferEncoding(Buffer, Encoding);
    // fname := Encoding.GetString(Buffer, Size, Length(Buffer) - Size);
    fname := WideStringOf(Buffer);
  finally
    Stream.Free;
  end;
end;
