阅读:3364回复:0
jsp中如何调用dwr
更多 发布于:2012-09-10 19:51
1、首先需要引入dwr.jar包到工程中的lib中;2、在web.xml中配置dwr,如下:<!—— DWR配置 ——>
  <servlet>
  <servlet-name>dwr-invoker</servlet-name>
  <servlet-class>org.directwebremoting.servlet.DwrServlet</servlet-class>
  <init-param>
  <param-name>scriptCompressed</param-name>
  <param-value>false</param-value>
  </init-param>
  </servlet>
  <servlet-mapping>
  <url-pattern>/dwr/*</url-pattern>
  </servlet-mapping>
  3、然后在WEB-INF下创建一个dwr.xml,并在里面将调用处理类配置,例如:<dwr> <allow> <convert match="com.po.OneSearchDto" converter="bean"> <param name="include" value="resname,resid"></param> </convert>
  <create javascript="GetDataBaseRes" creator="new"> <param name="class" value="com.util.GetDataBaseRes"></param> <include method="getDataBaseRes"/> </create>
  </allow> </dwr>
  4、然后在需要调用的jsp中,将调用处理js类引入,如下:<% String contextPath = request.getContextPath();%> <script type='text/javascript' src='<%=contextPath %>/dwr/interface/GetDataBaseRes.js'></script> <script type='text/javascript' src='<%=contextPath %>/dwr/engine.js'></script> <script type='text/javascript' src='<%=contextPath %>/dwr/util.js'></script>
  调用的js例子如下:function query(){ var keyword = document.getElementById("keyword")。value;var dataStr = "";var arr = document.getElementsByName("checkboxData");for(var i=0;i<arr.length;i++){ if(arr.checked){ dataStr+=","+arr.value;} GetDataBaseRes.getDataBaseRes(keyword,dataStr,disPoseRes);
  function disPoseRes(str){ alert(str);}
  5、如果需要在dwr调用类中获得session,或者request,如下:org.directwebremoting.WebContext wc = org.directwebremoting.WebContextFactory.get();HttpSession session = wc.getSession();HttpServletRequest request = wc.getHttpServletRequest();
