阅读:5043回复:0
用ASP实现对MP3曲目信息的操作
更多 发布于:2012-09-10 21:41
  先简单说一下MP3的ID3 标记,因为主要是操作这个玩意
  MP3最开始的时候没有我们今天看到的那样,有歌手、年代,专集等等信息
  只有一些简单的参数如yes/no来表示是不是privated或者copyrighted等信息,这样对MP3的相关工作带来了很多不便,1996年的时候有个老外提出来在每个MP3后面追加一段数据,用以存放上述的那些信息,后来就发展成为id3 v1 据我所知的现在已经到1.1了,具体的还是自己去查一下吧
  还是老习惯,用metadata来引入DLL,我以前有文章贴过的,不知道的请自己去查
  看代码
  <!--METADATA TYPE="typelib"
  UUID="00000205-0000-0010-8000-00AA006D2EA4"
  NAME="ADODB Type Library"
  Function ConvertBin(Binary)
  'This function converts a binary byte into an ASCII byte.
  for i = 1 to LenB(Binary)
  strChar = chr(AscB(MidB(Binary,i,1)))
  ConvertBin = ConvertBin ; strChar
  Next
  End Function
  dim objStream
  dim strTag, strSongName, strArtist, strAlbum, strYear, _
  strComment, strGenre, strFile
  'Specify the folder to iterate through, displaying all the MP3s
  Const folder = "C:\mp3s\"
  'Grab the folder information
  Dim objFSO, objFolder, objFile
  Set objFSO = Server.CreateObject("Scripting.FileSYstemObject")
  Set objFolder = objFSO.GetFolder(folder)
  'Create the Stream object
  set objStream = Server.CreateObject("ADODB.Stream")
  objStream.Type = adTypeBinary
  'Loop through the files in the folder
  For Each objFile in objFolder.Files
  'Open the stream
  objStream.Open
  objStream.LoadFromFile objFile.Path
  'Read the last 128 bytes
  objStream.Position =objStream.size - 128
  'Read the ID3 v1 tag info
  strTag = ConvertBin(objStream.Read(3))
  if ucase(strTag) = "TAG" then
  strSongName = ConvertBin(objStream.Read(30))
  strArtist = ConvertBin(objStream.Read(30))
  strAlbum = ConvertBin(objStream.Read(30))
  strYear = ConvertBin(objStream.Read(4))
  strComment = ConvertBin(objStream.Read(30))
  end if
  'Display the results
  response.write "<table><tr><td colspan=2><h3>" ; _
  "ID3 Tag info for:</td></tr><tr>" ; _
  "<td colspan=2>" ; objFile.Name ; "</td></tr>"
  response.write "<tr><td><b>Artist: </b></td>" ; _
  "<td>" ; strArtist ; "</td></tr>"
  response.write "<tr><td><b>Track: </b></td>" ; _
  "<td>" ; strSongName; "</td></tr>"
  response.write "<tr><td><b>Album: </b></td>" ; _
  <td>" ; strAlbum ; "</td></tr>"
  response.write "<tr><td><b>Year: </b></td>" ; _
  "<td>" ; strYear ; "</td></tr>"
  response.write "<tr><td><b>Comment: </b>" ; _
  "</td><td>" ; strComment ; "</td></tr>"
  response.write "</table>"
  objStream.Close
  Response.Write "<p><hr><p>"
  Next
  Set objStream = Nothing'Clean up...
  自己试试吧
