阅读:9692回复:0
asp base64编码中文
更多 发布于:2012-09-10 21:41
在网上找了很久,终于找到一个可以用的!
Function base64Encode(sString)
    If sString = "" or IsNull(sString) Then
        base64Encode = ""
        Exit Function
    End If
    Dim xml_dom, Node
    Set xml_dom = CreateObject("Microsoft.XMLDOM")
    With xml_dom
        .loadXML ("<?xml version='1.0' ?> <root/>")
        Set Node = xml_dom.createElement("MyText")
        With Node
            .dataType = "bin.base64"
            .nodeTypedValue = Gb2312_Stream(sString)
            base64Encode = .Text
        End With
        xml_dom.documentElement.appendChild Node
    End With
    Set xml_dom = Nothing
End Function
Function base64uncode(sString)
        base64uncode = ""
        Exit Function
    End If
    Dim xml_dom, Node
    With xml_dom
        With Node
            .Text = sString
            base64uncode = Stream_GB2312(.nodeTypedValue)
        End With
    End With
End Function
Function Gb2312_Stream(sString)
    Dim dr
    Set dr = CreateObject("ADODB.Stream")
    With dr
        .Mode = 3
        .Type = 2
        .open
        .Charset = "gb2312"
        .WriteText sString
        .position = 0
        .Type = 1
        Gb2312_Stream = .Read
        .Close
    End With
    Set dr = Nothing www.atcpu.com
End Function
Function Stream_GB2312(sStream)
    Dim dr
    With dr
        .Mode = 3
        .Type = 1
        .open
        .Write sStream
        .position = 0
        .Type = 2
        .Charset = "gb2312"
        Stream_GB2312 = .ReadText
        .Close
    End With
    Set dr = Nothing
End Function
