阅读:4598回复:0
[系统教程]php发送邮件方法二1.(SMTP传输SMTP类)
更多 发布于:2012-09-12 05:30
[html]
<?php
define('SMTP_STATUS_NOT_CONNECTED', 1, TRUE);
define('SMTP_STATUS_CONNECTED', 2, TRUE);
class p8_smtp
    var $connection;
    var $recipients;
    var $headers;
    var $timeout;
    var $errors;
    var $status;
    var $body;
    var $from;
    var $host;
    var $port;
    var $helo;
    var $auth;
    var $user;
    var $pass;
     *  参数为一个数组
     *  host        SMTP 服务器的主机       默认:localhost
     *  port        SMTP 服务器的端口       默认:25
     *  helo        发送HELO命令的名称      默认:localhost
     *  user        SMTP 服务器的用户名     默认:空值
     *  pass        SMTP 服务器的登陆密码   默认:空值
     *  timeout     连接超时的时间          默认:5
     *  @return  bool
    function p8_smtp($params = array())
        if(!defined('CRLF')) define('CRLF', "\r\n", TRUE);
        $this->timeout  = 5;
        $this->status   = SMTP_STATUS_NOT_CONNECTED;
        $this->host     = 'localhost';
        $this->port     = 25;
        $this->auth     = FALSE;
        $this->user     = '';
        $this->pass     = '';
        $this->errors   = array();
        foreach($params as $key => $value)
            $this->$key = $value;
        $this->helo     = $this->host;
        //  如果没有设置用户名则不验证
        $this->auth = ('' == $this->user) ? FALSE : TRUE;
    function connect($params = array())
        if(!isset($this->status))
            $obj = new p8_smtp($params);
            if($obj->connect())
                $obj->status = SMTP_STATUS_CONNECTED;
            return $obj;
        else
            $this->connection = fsockopen($this->host, $this->port, $errno, $errstr, $this->timeout);
            socket_set_timeout($this->connection, 0, 250000);
            $greeting = $this->get_data();
            if(is_resource($this->connection))
                $this->status = 2;
                return $this->auth ? $this->ehlo() : $this->helo();
            else
                $this->errors[] = 'Failed to connect to server: '.$errstr;
                return FALSE;
     * 参数为数组
     * recipients      接收人的数组
     * from            发件人的地址,也将作为回复地址
     * headers         头部信息的数组
     * body            邮件的主体
    function send($params = array())
            $this->set($key, $value);
        if($this->is_connected())
            //  服务器是否需要验证
            if($this->auth)
                if(!$this->auth()) return FALSE;
            $this->mail($this->from);
            if(is_array($this->recipients))
                foreach($this->recipients as $value)
                    $this->rcpt($value);
            else
                $this->rcpt($this->recipients);
            if(!$this->data()) return FALSE;
            $headers = str_replace(CRLF.'.', CRLF.'..', trim(implode(CRLF, $this->headers)));
            $body    = str_replace(CRLF.'.', CRLF.'..', $this->body);
            $body    = $body[0] == '.' ? '.'.$body : $body;
            $this->send_data($headers);
            $this->send_data('');
            $this->send_data($body);
            $this->send_data('.');
            return (substr(trim($this->get_data()), 0, 3) === '250');
        else
            $this->errors[] = 'Not connected!';
            return FALSE;
    function helo()
                AND $this->send_data('HELO '.$this->helo)
                AND substr(trim($error = $this->get_data()), 0, 3) === '250' )
            return TRUE;
        else
            $this->errors[] = 'HELO command failed, output: ' . trim(substr(trim($error),3));
            return FALSE;
    function ehlo()
                AND $this->send_data('EHLO '.$this->helo)
            return TRUE;
        else
            $this->errors[] = 'EHLO command failed, output: ' . trim(substr(trim($error),3));
            return FALSE;
    function auth()
                AND $this->send_data('AUTH LOGIN')
                AND substr(trim($error = $this->get_data()), 0, 3) === '334'
                AND $this->send_data(base64_encode($this->user))            // Send username
                AND substr(trim($error = $this->get_data()),0,3) === '334'
                AND $this->send_data(base64_encode($this->pass))            // Send password
                AND substr(trim($error = $this->get_data()),0,3) === '235' )
            return TRUE;
        else
            $this->errors[] = 'AUTH command failed: ' . trim(substr(trim($error),3));
            return FALSE;
    function mail($from)
            AND $this->send_data('MAIL FROM:<'.$from.'>')
            AND substr(trim($this->get_data()), 0, 2) === '250' )
            return TRUE;
        else
            return FALSE;
    function rcpt($to)
            AND $this->send_data('RCPT TO:<'.$to.'>')
            AND substr(trim($error = $this->get_data()), 0, 2) === '25' )
            return TRUE;
        else
            $this->errors[] = trim(substr(trim($error), 3));
            return FALSE;
    function data()
            AND $this->send_data('DATA')
            AND substr(trim($error = $this->get_data()), 0, 3) === '354' )
            return TRUE;
        else
            return FALSE;
    function is_connected()
        return (is_resource($this->connection) AND ($this->status === SMTP_STATUS_CONNECTED));
    function send_data($data)
            return fwrite($this->connection, $data.CRLF, strlen($data)+2);
        else
            return FALSE;
    function ;get_data()
        $return = '';
        $line   = '';
            while(strpos($return, CRLF) === FALSE OR substr($line,3,1) !== ' ')
                $line    = fgets($this->connection, 512);
                $return .= $line;
            return $return;
        else
            return FALSE;
    function set($var, $value)
        $this->$var = $value;
        return TRUE;
} // End of class
class smtp
    var $debug;
    var $host;
    var $port;
    var $auth;
    var $user;
    var $pass;
    function smtp($host = "", $port = 25,$auth = false,$user,$pass){
        $this->host=$host;
        $this->port=$port;
        $this->auth=$auth;
        $this->user=$user;
        $this->pass=$pass;
    function sendmail($to,$from, $subject, $content, $T=0){
        global $webdb;
        //$name, $email, $subject, $content, $type=0
        $type=1;
        $name=array("{$webdb[webname]}会员");
        $email=array($to);
        $_CFG['smtp_host']= $this->host;
        $_CFG['smtp_port']= $this->port;
        $_CFG['smtp_user']= $this->user;
        $_CFG['smtp_pass']= $this->pass;
        $_CFG['name']= $webdb[webname];
        $_CFG['smtp_mail']= $from;
        //$name = "=?UTF-8?B?".base64_encode($name)."==?=";
        $subject = "=?gbk?B?".base64_encode($subject)."==?=";
        $content = base64_encode($content);
        $headers[] = "To:=?gbk?B?".base64_encode($name[0])."?= <$email[0]>";
        $headers[] = "From:=?gbk?B?".base64_encode($_CFG[name])."?= <$_CFG[smtp_mail]>";
        $headers[] = "MIME-Version: Blueidea v1.0";
        $headers[] = "X-Mailer: 9gongyu Mailer v1.0";
        //$headers[] = "From:=?UTF-8?B?".base64_encode($_CFG['shop_name'])."==?=<$_CFG[smtp_mail]>";
        $headers[] = "Subject:$subject";
        $headers[] = ($type == 0) ? "Content-Type: text/plain; charset=gbk; format=flowed" : "Content-Type: text/html; charset=gbk; format=flowed";
        $headers[] = "Content-Transfer-Encoding: base64";
        $headers[] = "Content-Disposition: inline";
        //    SMTP 服务器信息
        $params['host'] = $_CFG['smtp_host'];
        $params['port'] = $_CFG['smtp_port'];
        $params['user'] = $_CFG['smtp_user'];
        $params['pass'] = $_CFG['smtp_pass'];
        if (empty($params['host']) || empty($params['port']))
            // 如果没有设置主机和端口直接返回 false
            return false;
        else
            //  发送邮件
            $send_params['recipients']    = $email;
            $send_params['headers']        = $headers;
            $send_params['from']        = $_CFG['smtp_mail'];
            $send_params['body']        = $content;
            echo "<pre>";
            print_r($params);
            print_r($send_params);
            echo "</pre>";
            exit;
            $smtp = new p8_smtp($params);
            if($smtp->connect() AND $smtp->send($send_params))
                return TRUE;
            else
                return FALSE;
            } // end if
